player s Posted May 23, 2016 Share Posted May 23, 2016 New here recently bought a r33 series 1 turbo wanting a boost controller sure theres heaps of posts about this but i got about a $400 budget wat do u guys suggest thanks Link to comment https://www.sau.com.au/forums/topic/464966-boost-controller/ Share on other sites More sharing options...
sent Posted May 23, 2016 Share Posted May 23, 2016 Depends on what mods. A decent manual boost controller should be more than enough if you're only going for Stage 1. Link to comment https://www.sau.com.au/forums/topic/464966-boost-controller/#findComment-7731726 Share on other sites More sharing options...
dyl33 Posted May 23, 2016 Share Posted May 23, 2016 If your not remapping ecu or anything just do the high boost only mod. As for ebc's they all do the same thing just get the coolest one. But I do recommend not getting hks evc-s although still good, can be tricky to set up. Link to comment https://www.sau.com.au/forums/topic/464966-boost-controller/#findComment-7731734 Share on other sites More sharing options...
Trex Posted May 23, 2016 Share Posted May 23, 2016 Most aftermarket ecu's come with boost control functions. So buying one may be redundant. I have a turbosmart mbc if you were looking into winding more boost into your current car on the cheap. Pm me. Link to comment https://www.sau.com.au/forums/topic/464966-boost-controller/#findComment-7731743 Share on other sites More sharing options...
Dose Pipe Sutututu Posted May 23, 2016 Share Posted May 23, 2016 What's stage 1? 1 Link to comment https://www.sau.com.au/forums/topic/464966-boost-controller/#findComment-7731878 Share on other sites More sharing options...
owen1r Posted May 23, 2016 Share Posted May 23, 2016 The stage before stage 2. 1 Link to comment https://www.sau.com.au/forums/topic/464966-boost-controller/#findComment-7731884 Share on other sites More sharing options...
Dose Pipe Sutututu Posted May 23, 2016 Share Posted May 23, 2016 What's involved with mod(s) vs. stages? I'm new to this stage stuff. Link to comment https://www.sau.com.au/forums/topic/464966-boost-controller/#findComment-7731959 Share on other sites More sharing options...
Sklyn Posted May 23, 2016 Share Posted May 23, 2016 haha, using stages is like saying 'I want Coilovers'.. FFS they have coilovers from stock! aaanywho, my interpretation of stages on a 33 is something like stage 1 < 220rwkw stage 2 > 220rwkw Link to comment https://www.sau.com.au/forums/topic/464966-boost-controller/#findComment-7731998 Share on other sites More sharing options...
Dose Pipe Sutututu Posted May 23, 2016 Share Posted May 23, 2016 Stage 3 = 240 Stage 4 = 260 Stage 5 = 280 Stage 6 = 300 Stage 7 = 320 Stage 8 = 340 Stage 9 = 360 Stage 10 = 380 Dammit I failed, I'm at stage 9.5 Link to comment https://www.sau.com.au/forums/topic/464966-boost-controller/#findComment-7732030 Share on other sites More sharing options...
niZmO_Man Posted May 24, 2016 Share Posted May 24, 2016 New here recently bought a r33 series 1 turbo wanting a boost controller sure theres heaps of posts about this but i got about a $400 budget wat do u guys suggest thanks None. Unless you have a non standard turbo and a programmable ECU, you'll keep running into rich & retarded mode. 1 Link to comment https://www.sau.com.au/forums/topic/464966-boost-controller/#findComment-7732086 Share on other sites More sharing options...
sent Posted May 24, 2016 Share Posted May 24, 2016 Sorry to confuse. Stage 1 meant by the following mods http://nissanskyline.6te.net/tuning_GTS25T.htm Link to comment https://www.sau.com.au/forums/topic/464966-boost-controller/#findComment-7732508 Share on other sites More sharing options...
Ben C34 Posted May 24, 2016 Share Posted May 24, 2016 Stage Juan 1 Link to comment https://www.sau.com.au/forums/topic/464966-boost-controller/#findComment-7732610 Share on other sites More sharing options...
KiwiRS4T Posted May 26, 2016 Share Posted May 26, 2016 Don't bother with the boost controller till you have the 3in exhaust FMIC bigger turbo, new ecu and by then you'll be able to get a mac valve instead. Stage 1 mods are the things that you don't need but can afford - like pod filter, noisy BOV, aftermarket FPR. Link to comment https://www.sau.com.au/forums/topic/464966-boost-controller/#findComment-7734597 Share on other sites More sharing options...
niZmO_Man Posted May 27, 2016 Share Posted May 27, 2016 Stage JuanWhich stage? Link to comment https://www.sau.com.au/forums/topic/464966-boost-controller/#findComment-7735329 Share on other sites More sharing options...
WMDC35 Posted May 27, 2016 Share Posted May 27, 2016 E Boost Street, or for a bit more the 120psi E Boost 2 which would cover you up to stage H-A 1 Link to comment https://www.sau.com.au/forums/topic/464966-boost-controller/#findComment-7735362 Share on other sites More sharing options...
1993 r32 Posted June 17, 2016 Share Posted June 17, 2016 I got a spare dual stage boost controler on the cheap buddy if ya want Link to comment https://www.sau.com.au/forums/topic/464966-boost-controller/#findComment-7747105 Share on other sites More sharing options...
omnigear Posted June 18, 2016 Share Posted June 18, 2016 Ark design boost controller is what i am using, decent for 150$usd no complaints Link to comment https://www.sau.com.au/forums/topic/464966-boost-controller/#findComment-7747596 Share on other sites More sharing options...
