Ok, it's a long read and I am trying to include as much detail as possible. Please read and help!
So I have been racking my brain for way longer than I would care to admit to, I've read probably hundreds of threads from all over the internet and still have no idea what is wrong with my car.
Background info.
R32 GTR engine swapped for R33 RB26 which had been built by Mercury Motorsport a few years ago and saw seldom use since then.
Engine was running when it was removed from the previous owners vehicle. Sump and cradle were removed to sight internals. Bearings replaced with Cosworth items.
Engine was installed into my car after receiving a few additional parts (see below)
First start up was relatively smooth, built up oil pressure, cranked, started, coughed a bit, knock sensors were not in, this was on a Nistune ECU.
Car info before swap
R32 GTR
R32 RB26
GT2860R -7's
Standard AFM's
Siemens 610cc injectors
Walbro 460LPH pump
Turbosmart E-Boost street
Nistune ECU tuned by MRC Dyno
New Parts
R33 RB26 built by mercury motorsport (forged internals)
Tomei 260deg 9.15mm lift cams
Tomei valve springs
Tomei cam gears (set to 0/0)
Ross Harmonic Balancer
After the initial start up (which I believe this issue was still present, just masked by holding revs around 3k) the car was left for several months.
Nothing significant changed. Battery was replaced, new fuel added, oil and fuel filters changed.
The Issue
The engine will crank, but either struggle to start or cough and die.
Holding a constant throttle the engine will start, sit at approx 1,200rpm, cough a lot and then do one of two things.
Either A. Start firing sporadically incl. firing so early you can hear it firing back into the plenum!
or B. Randomly kick up it's revs, anywhere between 2,000 - 4,000rpm with no extra throttle input at all.
Both of these scenarios usually result in me turning the car off which then results in a loud pressure release sound (nothing venting externally) and me crying quietly in a corner.
Things I have tried
Unplug AFM's = No Change.
Resoldered AFM's = No change.
Unplug 02 Sensors = No change.
Replace Crank Angle Sensor = No change.
Replace igniter module = No change.
Rearrange coil packs = No change.
Replace coil pack loom = No change.
Replace spark plugs = No change.
Replace Nistune with Power FC = No change.
Please. Help?
Edited by PitlanePhotos
Are either of the ECUs tuned for the 610cc injectors? Also how is your base fuel pressure and or fuel dampening (if any)?
Btw, Nistune needs the knock sensor flags disabled if you're going to unplug them as you've done
The Nistune was tuned with the 610cc's. Ran for 2 years with them. The power FC has had the injector %'s and latencies changed to suit.
Fuel pressure is approx 3bar, in tank regulator has been removed, fuel rail reg remains.
The car was run with the nistune, with knock sensors both connected AND disconnected.
And swapping to the Power FC made no difference so I don't see the issue being with the nistune (although it would have been nice and simple)
Power FC does not read any knocking when idle, but does register a tiny amount when the engine is coughing and spluttering as you would imagine.
Are your fuel lines all hard braided Teflon hoses?
Also do you have a wideband connected?
Not braided. But fresh E85 rated hose.
Fuel is BP ultimate though.
I do not have a wideband connected unfortunately.
    • I've owned a few scooters over the years, a Vespa PX oil burner was my first scooter, followed by a few others, including a little 50cc BeeWee that I used as a barracks bike, and I've had a blast on all of them, they really are the cheapest for of city/suburb transport around The only issue with scooters in Australia is lots of people look down on them due to their size,  maybe they need a big bike to make up for something else where they are lacking, unlike Europe and Asia where every man an their dog owns one, and now that filtering is legal in NSW, local traffic is never a issue Not to say I haven't owned my share of big cc bikes over the years, but they were for more blasting through the hills or Hwy riding where it needed to sit on Hwy speeds Safety wise, I ride like everyone is always trying to kill me, everyone is running a red, or running stop/give way signs, or generally asleep at the wheel, which most people are duringtheir commute, I also ride really safe, and give myself, and everyone else enough room in case I need to pull some hasty evasive actions, I've done a few rider training days over the years, which has come in handy on more than a few occasions  As for mods, there's nothing really, and yes your right about aftermarket exhaust, all you get is loud and obnoxious noises from them, like every 250-300 cc you hear with a aftermarket muffler, in saying this I did put a rear muffler from a 125 Aprilla on one of my old 125 scooters, it was horrendous and no amount of full face helmet and ear plugs would dampen that noise As for coming from the Harley, and what a overpriced POS that was, I no longer do big rides as my poor old busted joints ache after about 1/2 an hour of riding, long cruises are so much more enjoyable now in a car, so a big bike would be pointless
    • Oh wow, it's easy to forget how cheap these can be. Probably the cheapest way to travel. Though people in cars here tend to be morons and I would not feel very safe. Were scooters ever big in Australia? It used to be the thing growing up in Europe ~20 years ago. 50/70/125ccm Peugeot or Yamaha and some others. Utterly obnoxious Polini race exhausts. Kick stands that slant as much as possible. So loud. So much noise for really not moving very fast at all. But it felt cool at the time. Not sure where I'm going with this, but there is an aftermarket for mopeds! Though I'd have pictured you more for a Goldwing kind of guy after growing out of the Harley.
    • You need to know I am sorry for this.
    • As the MX5 isn't apparently "manly" enough, and I need something for runs to the local shops, and also take to my part time job at the salon, basically I can keep the MX5 away from car parks and stuff......like "flying lockers", I was wondering what I could buy to fix this issue LOL, I pick up a new Yamaha 125 Delight this arvo from Trooper Lu, basically a R1 that you can fit a slab of beer on between your feet, also, it was $29400 cheaper than a R1, so actually it's 2 x better than a R1
    • Nah. H2S. H2S is "rotten egg gas", which is what is associated with no cat. SO2 is equally nasty, and if you've ever smelt it you'll know all about it. More of a choking, acid in the back of the throat sort of thing. But you can only smell it in a narrow range up to about 1ppm. Above that, it irritates your mucous membranes, but you don't smell it.
