General/overall
One lady owner, car has never been thrashed, Except on weekends
This is a race car with rego plates and people should look at it as such
I have had the car for 4 years and have slowly developed it over time to make it a reliable track car. If it has shown signs of weakness it has been replaced
Below is a quick list of what I can remember basically everything has been upgraded to make it a better and more reliable track car( you would be horrified if you knew how much I had spent on it)
R33 Gtr shell s3 1997 Qm1 White non v spec
Registered till November 2016 in nsw
Jun dry carbon lip( ausi made carbon cubed(CCC))
Custom front under tray (CCC)
Custom front splitter ( Bunnings)
Carbon canards
Carbon vented bonnet aero catches( Jap with fade)
Carbon n1 rear spoiler (CCC)
18x10.5 +15 enkin rpf1 295 ao50 soft
Driveline
Engine
Stock 33 motor good compression( come over have a beer and I'll do a compression test for you)
Arp head studs
Tomie type b exhaust cam
Full belts and major service completed 3k ago
This thing is serviced every 200km or every second track day whichever comes first
Diffs
Rear os giken super lock lsd
Front os giken 1.5 lsd
Enlarged sump
Gearbox is os giken 1-5 cluster
Clutch is os giken Tripple plate
All above put together by award diff
Oil control ( this has evolved over my ownership of about 20 gtrs to what it is below)
Custom catch can setup
Autech upper catch can on top of engine with 4 breathers
Custom cpc catch can
Tripple vent to sump
One dash 12 from nismo oil cap
One dash from cpc catch can
One -10 from au tech can to electric oil pump to passengers side ( this is activated above 5k Rpm)
Accusump plumbed to boot with braided lines
Cooling
Oil cooler to front of radiator
Pwr cross flow radiator
Hks inter cooler
Greedy bov
Cold side
Nismo intake plenum
Metal gaskets all round
2000cc injectors
Hot side( 1k old)
6 boob manifold twin scroll
Twin gate
Egt probs
Custom Dvs jez setup( intake, ic pipe, 3.5 inch dump, screamers, heat wrapped, braided lines ect)
Exhaust
Racepace 3.5 inch super quiet so No
attention by police
Fuel
Braided lines throughout
Walbro in tank
Filter to surge
Surge with twin 044
E85 sensor
Inline filter to injectors
Fuel rail anondised
Fuel reg adjustable
Braided return with inline filter
Fuel cooler mounted under boot
Interior
Agi Tarmac rally spec cage
Spar I Evo xl seat custom mount
Detachable steering wheel
Nismo gauges
Rpm harness
Roll cage padded
Brakes
Ap endurance setup
Front
355 6 piston Ap racing endurance kit
36 mm full floating rotors
Endurance calipers 35mm pad each side
Race brakes custom lines
Spare set of rotors
4 sets of front pads
Rear
330 4 piston endurance calipers
Full floating
Custom lines
Spare rotors
3 sets of pads
Inline hydraulic handbreak with lockout for Parking
Ap balance bar setup
Twin master
I cabin adjustable on the road
These brakes will rip your face off and love a beating
Suspension
Struts
Race pace tein Rs remote canister stuff
Only about 2k old
Front
IKEA lower arms, castor rods and camber arms
Rear
Stock lower arms
Otomoto camber arm
Nismo upper arm
Hicas
Hicas delete with no bushes
Electronic
Haltech plug in pro
Data logger dash God speedo lap times
Flex tune
6 egts
Wide band
Oil pressure
Boost control
Fuel temp
Fuel pressure
Car runs oil pressure, fuel pressure and a few other protections
Rusic 4wd controller
Basically has everything halter have sells
Power
360rwkw at 17psi
400 at 21psi
Extra parts for extra
s3 front lip
Stock Gtr bonnet
295 ao50 medium rubber
Asking price 50k lots of money I know
If it doesn't sell I'll just part it out for more
Reason for sale
Might buy a r35 or I might buy a r34, have not decided
Located lower mountains Sydney
post-219-0-56210200-1464082330_thumb.jpegpost-219-0-88330500-1464082341_thumb.jpegpost-219-0-20142800-1464082354_thumb.jpegpost-219-0-57336500-1464082363_thumb.jpegpost-219-0-73920100-1464082373_thumb.jpegpost-219-0-53712000-1464082391_thumb.jpegpost-219-0-38073700-1464082400_thumb.jpegpost-219-0-52317900-1464082410_thumb.jpegpost-219-0-33209000-1464082421_thumb.jpegpost-219-0-92933300-1464082431_thumb.jpegpost-219-0-31640200-1464082443_thumb.jpegpost-219-0-73214900-1464082453_thumb.jpegpost-219-0-22648800-1464082464_thumb.jpegpost-219-0-59563200-1464082472_thumb.jpeg
  • Like 4
https://www.sau.com.au/forums/topic/464992-1997-s3-r33-gtr-one-lady-owner/
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
