Catchy title got you - It's not time to rebuild the engine like you may have figured, but rather everything else.
I picked up a series 1 auto for pennies since it needs all the suspension, and some steering components replaced. Bit of a job, but not necessarily why I'm starting this thread. The car, surprisingly, didn't have any maintenance history. You know what that means! Replace all the things! I'm new to Australia, so I'm not sure where the best deals are for this stuff are.
I'm pretty sure I have the suspension all sorted out, but as far as acc belts, timing belt kit, water pump, water pump seal goop, and spark plug online suppliers go, I'm pretty lost. I've seen some ebay listings as low as $200 for complete kits inc. water pump, and then I've seen kits locally (gold coast) with all the same stuff for $600.
Can anyone point me in the right direction? Unless someone here just so happens to have all of this BNIB at home, then I'll buy yours.
Cheers.
Before anyone mentions how I should swap the manual trans in, I will, in due time. It's certainly shitty seeing a swap in the classifieds going for $1100 right now.
https://www.sau.com.au/forums/topic/465002-its-rebuild-time/
    • The spray cans were in the "Kiln" room whilst I was preping the parts,  so probably around 2 hours to get them warmed up, the kiln room has 3 small ovens running at 100°c, 3 medium sized ovens running 100°c, and the large one I used running at 80°c, the room itself was about 28°c, I also spent a bit of time taping up the parts in the room as well, and by the time I was done I would assume that the parts were around that 28°c As for power, I expect a couple of Killerwasps up high would be achievable with the current mods, I'm still running the MZR 2.0 intake and throttle body, and there is a slight mismatch with the 2.0 intake (smaller) and 2.5 intake ports (larger) on the head, this intake is matched and specifically designed to fix this issue with the ports mismatch, the throttle body is also a couple of mm larger, OEM is 65mm, the Bosch is 68mm In the end it will look "prettier" than the molded plastic thing that is the OEM MZR 2.0 intake As for the LSD, it's the OEM Torsen which works fine for what I use the car for, plus, basically no maintenance apart from the occasional oil change
    • I was at Tunehouse in Marrickville (great team over there really know their VR's) , and I spotted this Very clean R35.
    • Mate , I have the same issue right now with the exhaust noise , if you can tell me what your local guy did , I'll talk to my guys and see if they can do the same. Power is good but it just too loud when put it down.
    • The other trick I've found with wrinkle black is to put the can in hot water for a bit to warm the paint up, and to pre-heat whatever you're painting. It'll be interesting to see if you pick up any power with the intake, following with interest. Got a proper lsd for this?
