crankyfrank118 Posted May 25, 2016 Author Share Posted May 25, 2016 Yea no flutter ever. Just a gush from the pod. Link to comment https://www.sau.com.au/forums/topic/465008-no-compression-surge-or-flutter-with-blocked-bov/page/2/#findComment-7733667 Share on other sites More sharing options...
XGTRX Posted May 25, 2016 Share Posted May 25, 2016 But in all seriousness. I don't use any bov, never will again. They all leak and cause serious lack of power around 10-30% throttle. That's just my personal opinion But I thought they help with transient response. Link to comment https://www.sau.com.au/forums/topic/465008-no-compression-surge-or-flutter-with-blocked-bov/page/2/#findComment-7733726 Share on other sites More sharing options...
89CAL Posted May 25, 2016 Share Posted May 25, 2016 I would expect the stock BOV to open when boost in the cooler pipes, purely because of the softness of the spring An aftermarket BOV adjusted to a hard setting is more likely to stay closed The stock BOV's do have that little bypass hole as well, wether that makes a difference or not BOV's work off pressure differential. Imagine for arguments sake the spring is worth 2psi, so with the car boosting it has 10psi on the cooler pipe side and 10psi on the top of the valve, so with the spring 12psi on the top, obviously 12 beats 10 so BOV stays closed. Close throttle, vacuum occurs in the manifold so now you have 10psi on the cooler pipe side and -10 on the top of the valve + 2psi so therefore -8psi With the boost/vac line removed, you only ever have the 2psi of spring pressure holding it closed, so as soon as there is any more than 2psi in the system the valve will open These are just rough numbers, but remembering how soft the stock BOV was to open by pushing it in with my thumb, I would suspect it would stay open alot So really what you should have is a whoosh of air then possibly a small flutter at the end when the spring overcomes the valve. Although then you have to think about the effect the low pressure/vac that is present in the recirc pipe is having 1 Link to comment https://www.sau.com.au/forums/topic/465008-no-compression-surge-or-flutter-with-blocked-bov/page/2/#findComment-7733920 Share on other sites More sharing options...
Missileman Posted May 25, 2016 Share Posted May 25, 2016 But I thought they help with transient response. Pretty sure Tom said he's using an auto, but with a manual yeah when you get off the throttle when changing gears the recirculation valve will stop the compressor from stalling. Link to comment https://www.sau.com.au/forums/topic/465008-no-compression-surge-or-flutter-with-blocked-bov/page/2/#findComment-7733923 Share on other sites More sharing options...
Missileman Posted May 25, 2016 Share Posted May 25, 2016 I would expect the stock BOV to open when boost in the cooler pipes, purely because of the softness of the spring An aftermarket BOV adjusted to a hard setting is more likely to stay closed The stock BOV's do have that little bypass hole as well, wether that makes a difference or not BOV's work off pressure differential. Imagine for arguments sake the spring is worth 2psi, so with the car boosting it has 10psi on the cooler pipe side and 10psi on the top of the valve, so with the spring 12psi on the top, obviously 12 beats 10 so BOV stays closed. Close throttle, vacuum occurs in the manifold so now you have 10psi on the cooler pipe side and -10 on the top of the valve + 2psi so therefore -8psi With the boost/vac line removed, you only ever have the 2psi of spring pressure holding it closed, so as soon as there is any more than 2psi in the system the valve will open These are just rough numbers, but remembering how soft the stock BOV was to open by pushing it in with my thumb, I would suspect it would stay open alot So really what you should have is a whoosh of air then possibly a small flutter at the end when the spring overcomes the valve. Although then you have to think about the effect the low pressure/vac that is present in the recirc pipe is having Even more so if the diameter of the diaphragm is lager than the seating surface of the valve. Link to comment https://www.sau.com.au/forums/topic/465008-no-compression-surge-or-flutter-with-blocked-bov/page/2/#findComment-7733929 Share on other sites More sharing options...
XGTRX Posted May 25, 2016 Share Posted May 25, 2016 But then the turbo will break when it spins backwardsAccording to Facebook, yes u are correct.[emoji1] [emoji1] [emoji1] 1 Link to comment https://www.sau.com.au/forums/topic/465008-no-compression-surge-or-flutter-with-blocked-bov/page/2/#findComment-7733930 Share on other sites More sharing options...
XGTRX Posted May 25, 2016 Share Posted May 25, 2016 Pretty sure Tom said he's using an auto, but with a manual yeah when you get off the throttle when changing gears the recirculation valve will stop the compressor from stalling.Hmmmm. I am in 2 minds atm. In a GTR I have the BOVs venting in the guard and considering removing them altogether So the question is whether or not I will see a noticeable change in transient response on part throttle. Any advice would be great. Link to comment https://www.sau.com.au/forums/topic/465008-no-compression-surge-or-flutter-with-blocked-bov/page/2/#findComment-7733967 Share on other sites More sharing options...
Missileman Posted May 25, 2016 Share Posted May 25, 2016 Block em off like Jonny said with a coke can gasket, then go for a run and see if there is much difference. Link to comment https://www.sau.com.au/forums/topic/465008-no-compression-surge-or-flutter-with-blocked-bov/page/2/#findComment-7733979 Share on other sites More sharing options...
Dose Pipe Sutututu Posted May 25, 2016 Share Posted May 25, 2016 Stock turbo doses the best, I know Link to comment https://www.sau.com.au/forums/topic/465008-no-compression-surge-or-flutter-with-blocked-bov/page/2/#findComment-7733986 Share on other sites More sharing options...
Dose Pipe Sutututu Posted May 25, 2016 Share Posted May 25, 2016 back in the days when my piece of shit was even more of a piece of shit... but it dosed hard No Airbox Lid: With Airbox Lid: And Last Year: Link to comment https://www.sau.com.au/forums/topic/465008-no-compression-surge-or-flutter-with-blocked-bov/page/2/#findComment-7733988 Share on other sites More sharing options...
crankyfrank118 Posted May 25, 2016 Author Share Posted May 25, 2016 Haha mine def dosent sound like that! Link to comment https://www.sau.com.au/forums/topic/465008-no-compression-surge-or-flutter-with-blocked-bov/page/2/#findComment-7734001 Share on other sites More sharing options...
Dose Pipe Sutututu Posted May 25, 2016 Share Posted May 25, 2016 aluminium can between BOV & flange like I just said man! Link to comment https://www.sau.com.au/forums/topic/465008-no-compression-surge-or-flutter-with-blocked-bov/page/2/#findComment-7734016 Share on other sites More sharing options...
XGTRX Posted May 25, 2016 Share Posted May 25, 2016 https://youtu.be/Ye9ctbLqEq0 1 Link to comment https://www.sau.com.au/forums/topic/465008-no-compression-surge-or-flutter-with-blocked-bov/page/2/#findComment-7734031 Share on other sites More sharing options...
niZmO_Man Posted May 26, 2016 Share Posted May 26, 2016 My stock BOVs are fine . 1 Link to comment https://www.sau.com.au/forums/topic/465008-no-compression-surge-or-flutter-with-blocked-bov/page/2/#findComment-7734230 Share on other sites More sharing options...
XGTRX Posted May 29, 2016 Share Posted May 29, 2016 Just blocked off my BOVs for shits and giggles. Surprisingly transient response at part throttle has improved. Link to comment https://www.sau.com.au/forums/topic/465008-no-compression-surge-or-flutter-with-blocked-bov/page/2/#findComment-7736789 Share on other sites More sharing options...
Missileman Posted May 30, 2016 Share Posted May 30, 2016 What boost are running? Link to comment https://www.sau.com.au/forums/topic/465008-no-compression-surge-or-flutter-with-blocked-bov/page/2/#findComment-7737168 Share on other sites More sharing options...
XGTRX Posted May 30, 2016 Share Posted May 30, 2016 Only 19ish with a bleed valve, ebc not right yet. But I feel the difference that for sure. Link to comment https://www.sau.com.au/forums/topic/465008-no-compression-surge-or-flutter-with-blocked-bov/page/2/#findComment-7737287 Share on other sites More sharing options...
Missileman Posted May 30, 2016 Share Posted May 30, 2016 I blocked mine off this arvo and noticed zero difference, 14 psi, breed valve, auto trannie. Have you tried lubing the shafts on the rec-valves with some molly grease? mine used to stick a little open until I lubed it. Not much Sutututu either, stock intake pipe and airbox. Link to comment https://www.sau.com.au/forums/topic/465008-no-compression-surge-or-flutter-with-blocked-bov/page/2/#findComment-7737296 Share on other sites More sharing options...
XGTRX Posted May 30, 2016 Share Posted May 30, 2016 Yeah I noticed the plungers were pretty close to the edge of the outlet. But I never had a problem holding boost so I assume they are OK. I will lube them if I decide to go back. Link to comment https://www.sau.com.au/forums/topic/465008-no-compression-surge-or-flutter-with-blocked-bov/page/2/#findComment-7737333 Share on other sites More sharing options...
Missileman Posted May 30, 2016 Share Posted May 30, 2016 (edited) Did some quick calculations on my rb20 rec-valve, Valve seat is 1" diameter = 0.785² inches x 14 = 11lbs Diaphragm is 2" diameter = 3.14² inches x 14 = 44lbs estimated spring pressure 10 lbs so when at 14 psi boost, there is 44lbs pushing down from the diaphragm, 11lbs pushing up on the valve face, then add another 10lbs down for the spring so thats about 54lbs down compared to the 11lbs pushing back up from the 14psi of boost. To see how that changes at intermediate throttle positions you would need to put another pressure gauge before the butterfly in the throttle body, needless to say as soon the plenum approaches atmospheric pressure only the spring will be holding the valve closed. Please correct me if my physics is off Edited May 30, 2016 by Missileman Link to comment https://www.sau.com.au/forums/topic/465008-no-compression-surge-or-flutter-with-blocked-bov/page/2/#findComment-7737351 Share on other sites More sharing options...
