Hi all
My rb25 in my 31 is blowing white smoke and it pours out if you revv it abit.
Has perfect compression
Just replaced head gasket, head was machined, pressure tested, vacuumed tested
Inlet manifold gaskets replaced
No milky oil in sump or head
Turbos in good condition ( I doubled checked by unbolting it at the manifold and you can see the smoke and some liquid coming straight from the right port on the exhaust flange on the exhaust manifold so it's not coming from the turbo )
I'm out of ideas can someone please shed some light??
https://www.sau.com.au/forums/topic/465025-rb25det-clouds-of-white-smoke/
Do a warm dry and wet compression test. Also do a leak down test.
If you're saying it's coming straight from the exhaust ports then I would definitely say it's got nothing to do with your turbo unless it's leaking through the seal into the compressor side!
Also check your breather setup - make sure your pcv isn't blocked or any parts of your crankcase ventilation setup!
  • Like 1
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
