hey guys
just got an interesting question, would it be possible to convert a RWD car to an AWD car???
k i know anythings possible but within reason or course!!
For instance how about changing a Z32 300zx to AWD by using a GTR gearbox and drivetrain???
i havent a clue if it could work what do u gusy think???
any comments would be awsome
thanks p
https://www.sau.com.au/forums/topic/46503-rwd-awd/
Within reason, no and why when you have the GT-R.
Can it be done, yes anything can...IIRC ZELE international has entered a Z33 with GT-R running gear and RB26DETT in the Pikes Peak international hill climb.
https://www.sau.com.au/forums/topic/46503-rwd-awd/#findComment-944257
Anything possible, for sure. In fact there have even been a couple of AWD RX-7s cobbled together, one SA22C and one FC. The SA if I remember right (not guaranteed) had to have the engine moved forward and off to the side a bit. Used some front-drive components from a 626 and who knows what all else. Worked pretty well as a rally car though.
https://www.sau.com.au/forums/topic/46503-rwd-awd/#findComment-944803
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
