All parts are located in Blaxland NSW, 10min past Penrifff on the M4.
R32 GTR TEIN Super Streets: $250
Only removed as they were replaced with custom MCA/Bilstein coilovers.
They've been sitting in the garage for a while in the same spot and haven't leaked. They drove well on the street and stuck on the track pretty well.
Were purchased from Fulcrum in Qld, so they're Aussie spring rates to suit our roads, not the stiffer JDMYO-spec rates.
GTR Extended/baffled/gated sump: $1100
Has increase capacity by around 1.5L. Most workshops prefer to cut the factory cast sump floor and fabricate a sheetmetal one, but unless the floor is lowered, it'll give no increase in capacity from our approach, so we prefer to keep it in place to reduce any possible warpage during welding and keep maximum strength. We can increase capacity beyond the 1.5L shown, but feel it's unnecessary if the right cooling, baffles and oil pump are used.
This sump features -10 fittings on both sides of the sump which can be used to vent crank pressure to the head and increase oil flowback on engines with blowby issues or big boost applications. All fittings are above the windage tray to stop high g-forces moving oil up the lines.
The baffled windage tray shown has four 70x25mm gates with walls extending from the underside of the windage tray to the floor of the sump.
No oil pickup modifications are required for either baffle or extended sump mods. Leak tested and will come with -10 blanking caps as shown in pic and standard diff.
RB26 twin turbo split pipe with mod: $150 (actual pipe in pic, painted in heatproof 'aluminium' paint)
This modification stops compressor surge (shuffle) between aftermarket twin turbos. Some workshops like to cut the forward/upper of the pipe off and reweld across the top, but we prefer to slot from the rear to save welding across the top; we think it just looks neater.
We've read some owners in the UK have had back-to-back 10hp gains with this mod only, whether it's true or not, it'll definitely stop the turbo 'shuffle' on bigger twin turbos.
Some flow testing on Youtube:
Standard: https://www.youtube.com/watch?v=l8GUhVdko84
Modified: https://www.youtube.com/watch?v=xRX2NhlXB-c
Mark :)
0417 049 016
  • Like 1
TEINs gone, TT pipe gone, still have sump.
Heya NISR32.5,
I fabbed the sump for a customer who didn't come through with the remaining cash.
PM me if you'd like more info regarding your application etc
Mark :)
  • 3 weeks later...
  • 1 month later...
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
