Hey guys i have an r33 gtst which i am hoping to bring to around 230-240rwkw and keep lag minimal.
Current mods are:
10psi boost
Full 3 inch exhaust
Apexi pod filter
Blitz return flow cooler
Gtr fuel pump
Car is making 180atw
Upcoming mods:
Power fc
Bigger injectors
High flow turbo
Z32 afm
so my questions are.
1. Is it worth tracking down a r34 turbo to highflow over a r33 one? I heard the 34 can flow better but is it much laggier?
2. What size injectors should i be going for and any other mods needed to reach this power level.
3. Does anyone know a good tuner in melbourne, located in west suburbs but willing to travel.
Any help is very much appreciated im fairly new to skylines.
https://www.sau.com.au/forums/topic/465051-r33-gtst-a-few-questions/
You're in the right place.
21U Highflow and Adaptronic ECU from Hypergear in Somerton.
Injectors from Scotty.
Get it fitted up in Dandenong at Forced Motorworx and tuned by Trent @ Status Tuning in Keysborough.
The 21U R33 turbocharger is super responsive, that supports an average of 260rwkws on P98 fuel, 20psi @ 3500RPM.
The R34 turbocharger has an larger rear housing that is capable of making more power, handles more timing, we can also high flow it using our ceramic ball bearing system thats brings the optimum throttle response out of it. The turbocharger it self is capable of supporting the 270rwkws region in average, 20psi @ 3650RPM CBB or 3800RPM plain. If you have both turbos available, in my opinion OP6 is an better pick.
Pm sent
Thanks for all the info guys.
I will pm hypergear
Isn't 1000cc injectors overkill though? I was thinking i would only need around 555ccs
There's no point messing about with shitty old school injectors in the 550cc range. The modern Bosch ones will idle better than the crappy old ones even at twice the size. Plus then you will NEVER need to upgrade them, regardless of what you do (within reason).
  • Like 1
  • 3 weeks later...
Guys, I'm new to SAU, I'm actually buying a mates 33gts25t in roughly 3 weeks(cheers tax). I believe he's a member just not sure of his user name.
Anyway, I have a few questions seeing as this will be the second boosted car I've owned, first being a GT forester(let's not get into that) lol.
So basically we've done some minor mods and whatnot to it since I've been friends with him, and we aren't quite sure of the KW figure. Haven't been bothered to pay for a dyno.. Probably roughly 180-90ish
I know it's got the usual tasteful mods..
That being..
*Blitz Return Flow Front Mount
*3 inch cat back
*Walbro 255L pump(I believe)
*NGK Plugs
*Profec B2
Now when I get it I plan to go 3" turbo back.
Any tips or hints on how to get it around 220KW's without spending an arm or leg?
Any help would be greatly appreciated.
Cheers!
I was considering a Nistune.. Not sure what everyone's take is on them but I know they're roughly 500 brand new.
Well it will be sliding at some point, but casually not everyday.
i thought about a 2540 upgrade but I've heard some bad shit about them.
Contemplating going Bosch 500cc also.
Not sure on the AFM though.
Obvious place to point you for a turbo is Hypergear. Look at the Hypergear thread. All of it. The 21U highflow will do up towards 250rwkW. You will need the Nistune of course and it's a sensible choice. It's less easy on R33s but at least it's not as bad as it used to be. You should look into what it actually takes to achieve it (effort and cost wise) then decide if any of the other options make any sense to you (such as an old PFC, or an Adaptronic, to name a couple of options). You will need injectors to make the best use of the turbo. Likewise a Z32 AFM (if you stick with Nistune or PFC).
Already messaged Hypergear. I was going to hi-flow the T25, but on second thoughts seemed to be a waste of money as such.
I'm not sure why everyone leans towards a power fc these days.. Majority of the lads I know that have stageas or skylines always have the fc. What's the difference? Besides the obvious hand controller which gives you all the readings.
I'd prefer to spend less money on a Nistune because I'm not building a weapon that has no purpose of being road driven, as it can't be driven to its full potential, and well having a skyline with a reading of 600kws at a drift meet is pretty pointless, as long as it holds sideways then that's all that matters really.
Probably because Power FC are cheap these days and if you want to Nistune an R33 you have to find a suitable Z32 ecu and set up the VCT control (if applicable).
I don't see how a hg high flow is a waste of money. 250-260rwkw on 98 and 300-310 on e85 and full boost by 3.4-3.5k rpm for $850 and is a 100% bolt on affair, no spacers or other bull shit required. I don't believe you will find any other turbo in that price range and unless you are chasing massive HP its a no brainer for most. Hypergear also does excellent pricing on adaptronic ECU's if you buy a turbo from him. You won't require an AFM or boost controller with one of them either, they do all the fancy crap, flex fuel, wb input, launch control and the customer service and support from adaptronic is phenomenol. My 2c.
    • Any number of different ways. Have the coils draw sufficient current to provide contact wetting. Use different contacts in the switch, either by material or design, better suited to the low current drawn by a relay coil. Etc.
    • Hmm, how does the R34 manage to have headlight relays then without getting excessive carbon buildup on the headlight switch contacts?
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
