I have had over 25 cars in my life BUT the windscreen reflection on my 34 is something else, never had anything like this before. Had to change the undies a couple of times when I got home, lol
Always drive with sunnies on during the day.
I drive a lot early in the morning on a bendy road, come out of, or into a corner into the sun and the road disappears, I mean , gone! white out!
Cleaned inside and out, run the washers when it starts to look dirty ish, use the sun visor and still scary. :yes:
I put a black mat out of the Tiida on the dash and that helps a lot, 50% better but that goes where it wants when you accelerate hard . Just ordered a R34GTR dash mat and and I am sure it will help the glare.
Just wonder if some type of tinting could help or maybe it has been used and is the problem because it has scratched up or something ????
Funny you brought this up. I had the exact same thing happen today, first time ever I was driving blind.
The windscreen just needs a proper clean. Sometimes you need to re do it over and over again until streaks and glare are gone.
What do you use to clean your inside? Most products leave a film behind that will intensify glare.
Hi Peter,
Use - 0000 fine steel wool you can get from Bunnings on the outside of your windscreen.
Give it a good rub over.
Then use Rainx following instructions.
Lastly get a 10-15cm sun strip for your front windscreen.
  • Like 2
I have to say , driving blind(not drunk) is one scary Mother f er
Some of the protectant products for the dash are too shinny, I think the angle of the windscreen and how close it is to the dash might also play a part ?
I have some glass polish and I will try it in the morning and see how that works ?
I have the Bosch GEX 150 Pro sander/polisher and all of the different microfibre cloths, pads, polish and a glass cleaning kit. Think I will have to get serious with it :)
Just did the drivers side earlier this morning and went for a run and it is a bit better but the mat I covered the dash with works the best to help stop the reflection.
I will have the full R34GTR dash mat coming early this week and I will do a full windscreen clean and polish and see how it goes.
The windscreen is only 1 hand width away from the dash at the front of the dash, on the Tiida, it is 1 hands width close to the windscreen and I have no reflection problem, I just wonder if the dash being so close to the windscreen could cause the reflection ?
This is why I HATE silicon on the interior.
Way too much glare.
Also, watch the glass polishing, as it can cause warped vision if you create high/low spots.
Sun in your face is easy, just drop the sun visor but that reflective glare is something else. It is only very early or late driving, no problem at other times. Maybe my eyes are stuffed ?
But , I have never had this type of glare in any other car and have used Armor All?
In the 34GTR it makes everything disappear, bloody scary, better than a radar camera to make you drive UNDER the speed limit :)
Now I have to watch out if I polish it unevenly , cant win, lol
I use Repco Eclips , not as shinny as Armor All but still shinny
Going to get super fine 0000 steel wool later and also try the Rainx
But I think the Dash Cover will do the trick and it has the cut outs for the Aircon etc. I will take a couple of pics and post them, should have it tomorrow.
Thanks
cleaning the windscreen wont help much, its only good if its hazy and affects your vision at night, but doesn't appears to be the case
its probably just a fundamental design issue with the car - shape of the dash and the angles between dash, windscreen and driver's head
Plastidip the dash matt black :P.
Funny you said that , got the dash mat today and stuff me if it is not a Nylon or similar and Fn sparkles when the sun is on it. I will go for a run in the morning and see what happens.
Plastidip, have to look it up ??????
If it is crap I was thinking a matt black spray might be ok, not too sure how it would look or smell , should be OK when totally dry ?
I think the design is the issue, windscreen very close to the dash and maybe since I am short I am closer than most ?
plasti-dip is a mat black spray.
AFAIK, its a liquified rubber.
You can pull it off fairly easily too.
Probably do the job, but sounds like it might look a bit rough sitting on top of the dash ?
The dash mat is not a flat surface, some sort of carpet like material. Might try some black dye first if the mat causes glare, could always try the plasti-dip after if needed and if it comes off easily there should not be a problem if it looks a bit off :/
Let you know how the glare is tomorrow and take a pic, the mat itself looks , well OK ish but better than I thought it would look :)
Or you could use a pillow......jus sayin'
Hahaha, first car was a 1936 Dodge @ 15, needed 2 pillows,1 to lift me up to see over the bonnet and the other so I could work the clutch, brake and go go, so do not knock the worth of a good pillow or 2, lol
Had a run this morning but left a bit late but there was no glare with this dash mat, have to do it again earlier or later this arvo to get a true result
As you can see from the pics, there are cut out for the aircon and passenger airbags. So at least they put some thought in making it.
Oh gawds one of those mats. I'd spray the mat a, erm, matt colour to remove the shiny-ness.
That is the plan if it does not cut the glare down and with that Nylon type matting I guess it will not be too good. I think I will try the dye first to see how it goes ?
Have you had one of these, hard to tell when you see them on the web :/
Fit OK
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
