Ok. This is a sad/frustrating update for me. I have to say I normally don't post things like this, but my frustration with Raw Brokerage is pretty high at the moment. Ricky has been great with trying to resolve some issues, but I keep revealing more and more. The story goes something like this......:drama:
I took the car to Hal at Dynosty in Louisville (could speak highly enough about this group) a couple weeks ago to get the initial startup, break in tune and dyno completed. I ended up having to leave the car with them due to some punctuality issues on my end.
So later that next day I get a call from the guys at Dynosty and they have some good news and some bad news. They tell me that they got the car turned over, idles well, but the valve train was really noisy. They have a guy with some RB experience and guessed it sounded like valve lash clearance issues. They sent me a video and suggested that I have them pull the cam covers and measure out the clearances. Keep in mind this car has only idled and got up to operating temps two times total before this. There was even still assembly lube in the head when they pulled the covers. I mean we are talking still really fresh from Raw Brokerage's build.
After I give the ok to measure out the clearances, they give me a call and a couple emails with what they found. They advised that every one of the lash measured between .019"-.022". They even sent pictures showing that this error on the build did damage to my camshafts and lifter buckets. Will attach pictures. Nothing that was detrimental by any means, but still frustrating to drop a huge coin on a build to only have these issues.
After finding this, the guys at Dynosty suggested the whole head needed to be removed and gone through again just to make sure everything else was kosher.  Not to mention took the opportunity to order a fresh set of Tomei poncams from Japan. This is where we contacted Ricky at Raw Brokerage. Great guy and was more than willing to try and figure out the issue. Raw Brokerage wants the head shipped back to them down in Florida to go over. Understandable, but geez. Now Dynosty has to get paid to remove and reinstall the cylinder head. Not to mention the headgasket and other associated cylinder head gasket would need to be replaced.
Dynosty officially removed the Cylinder head this morning to prepare for shipment and found a couple more issues. First being the headgasket. This was supposed to be a brand new Tomei gasket. Clearly it was already failing after two short idle periods on the motor. The second issue being small scratches found in cylinder wall number one from the oil control ring. Again nothing that would cause the motor to crash and burn, but still unacceptable when dropping such large coin on a fresh build top to bottom.
Bottom line frustrated and a major set back.
  • 5 months later...
Ok guys...... Sorry this thread has not been updated in such a long time. Long story short, they car is still at Dynosty in pieces. #HATEMYLIFE. Here goes my long sob story. I would like to state for the record the purpose of this post is not to bash on Raw Brokerage by any means, but just to document my build and share my experience with others.
So we last left off with my cylinder head being shipped back to Raw Brokerage to get looked over to find out what exactly happened. While at Raw Brokerage Ricky and company turned my Cylinder head around very quickly and I was grateful for that. While it was back apart we went ahead and has some Brian Crower Valve Springs installed along with some Brian Crower bronze valve guides for good measure. After about 3-4 weeks time, a box ended back up on the door step of Dynosty. Raw Brokerage even sent a brand new Tomei headgasket back with the second attempt on the Cylinder head. Needless to say I was feeling pretty good about this time around.....
The RB tech at Dynosty made sure all deck surfaces were clean enough to eat off of, and torqued down the RAW Brokerage pre-assembled cylinder head to factory spec.......
Ready for the kicker on this story?...... I get a call from Dynosty the day i knew they were going to start it again. I knew this couldn't be good..:picardfp:  The crew at Dynosty advised that the initial start up went much better than before and the valve lash sounded to be in spec compared to the prior attempt..... They left it to idle on the dyno so that it could get up to operating temp. They said within 5 minutes of idle the whole shop echoed with a loud screech that made everyone stop what there were doing. I was advised that following the noise the motor locked up.... SMH SMH FML!!!!!!!!!!!! They had me drive up to look at the carnage for myself. They pulled the exhaust side rocker cover and found that the mechanical timing was off by 3 or so teeth and found the following under the rocker cover......
They found metal shavings all around a lifter bucket. Brock the RB tech advised that they believe that a lifter bucket tolerance was not in spec and was too tight. So when the motor started to warm up it caused interference. They actually came to the conclusion the head at this point was trash due to the damage in the casting around the lifter buckets. I had them to go ahead and disassemble further to asses the destruction and found the following....
:facepalm: So here I was feeling like I had been bent over as I was out a Cylinder head (not the easiest and cheapest to find a replacement), out a brand new set of $550 Tomei camshafts, and the new headgasket. Not to mention all those metal shavings would have  been ingested by the bottom end as well. As much as I hated to do so, I had Dynosty schedule to pull the head yet again, and advised i was going to have them make this problem right as RAW brokerage couldn't seem to get the job done and was just costing me money. Needless to say I was left with this
I went ahead and made the call to Raw Brokerage to see how they wanted to proceed in resolving this. Keep in mind the second cylinder head that failed was fully assembled by Raw Brokerage and was just set on the block and torqued to spec by Dynosty.
Raw Brokerage asked me how I would like to proceed and came to the conclusion they would source me a brand new OEM casting, one more Tomei headgasket (they wanted the old one back?????), a partial refund on the machine work and assembly of the cylinder head, and asked to shake hands and part ways. I agreed to this knowing I wanted Dynosty to do all the work from here. 2 weeks later the box landed on the steps of dynosty. I was grateful that Ricky was able to source me a brand new OEM casting, due to them being on a backorder currently and may be harder and harder to get.
I gave dynosty the go ahead and pull the rest of the motor so that they could go over every bolt and bearing to insure all was correct. I didnt want to take a risk of something else going wrong having this brand new head. Not to mention the track record with the assembly from Raw Brokerage has not had the best track record
So here is where I am at to this date..... The motor is totally torn down. T machinist recieved the new cylinder head and the old one to trasfer all usable parts over along with getting a valve job done. I was advised the OEM valance had been cut past spec and could not be used again, so I was force to purchase all new Supertech valves to go with the prior installed Brian Crower goods.
Another thing I should note, upon the careful disassembly of the short block, Brock took note that all the pitons rights were clocked incorrectly. ALL SIX pistons had the ring gaps stacked right over top of the ones below it. This would have cause major issues with blow by and compression. Brock advised that there was no way with 10 minutes total of idle time that all six cylinders would have coincidentally aligned that way. Another incorrect assembly point from the original build by Raw Brokerage.
Anyway.... The block has been sent to get hot tanked to make sure all metal has been removed. New ACL bearing have been ordered and brand new piston rings are on order as well.....
I promise to keep this updated from here forward as i will receive periodic pictures of the third and final build attempt. I feel that every single part at this point has been upgraded and replaced at this point. I have been assured by Dynosty this will be down hill from here and this motor will be able to support 750hp plus.
I did decide to also purchase a Fluidampr to be installed upon reassmbly and TOMEI metal intake manifold and exhaust manifold gaskets...:2f2f:
Sorry to hear about the problems, although it's kind of good to know there are shops that don't know what they are doing on both side of the world....
Good luck with the reassembly, and I'd also have to give some credit to the engine shop for covering the cost of a new head; they are expensive and lots of times shops try and duck responsibility for their mistakes...
  • Like 1
Shit mate, that's a frustrating experience you've had!!  I really feel for you, it would be heart breaking!
Here's hoping 2017 brings nothing but good news so you can get this bad boy screaming around the roads in no time!
Looks like it is going to be a great machine when it is finished. A shame you are being let down in such an expensive way. Even top shops can do below par work when they have grown to a size where all the important work is not done by the principal who built the reputation. Hope you are on the road soon.  BTW can you get this car road legal or will it be track only?
Thanks for all the kind words everyone!!!! Thumbs up. I have used this site quite a bit on my build and some purchases. Its a shame you all are so far away. This engine is anything but familiar to people in this part of the world. I hope my journey is all down hill from here and hope to have it on the road (street legal.... kind of).
here is a picture just because with my new years beverage...... just turned midnight here
  • Like 1
  • 1 month later...
Got a quick picture from Dynosty yesterday of the completed short block.
And also decided to pick up a set of Tomei Cam gears as well since the whole thing is apart.... I dont know if I will be able to force myself to put the front cover back on now
  • Like 2
The moment of truth you all. I got some time on the dyno this morning and ironed out the initial tune on the car. It made right at 600whp due to being limited at fuel. I am very excited to pick the car up.... I am trying to figure out a way to upload a video that Dynosty posted to their facebook page
  • Like 3
Awesome result! You could try posting a link here or sharing directly on FB on the SAU group: https://www.facebook.com/groups/skylinesaustralia/
Awesome result!  600 HP (even 600 Yankee HP :2_grimacing:) is a whole lotta fun!  Good to know there's more in it too once you sort out some extra go juice to the front.
Can't wait to see a high speed blast down the road video (sounding like a Skyline!).
  • 2 months later...
Hello all. Sorry to the really delayed response. Hectic life and have been out of town. I have quite a few updates that I have done to the car that this thread does not reflect. I also have quite a few updates planned in the next couple weeks. I did bring the car to the first day of the import alliance meet in Atlanta if anyone had a chance to see it.
 So some new things on the car since I last posted include some brand new shoes. I decided to go with a genuine set of BBS wheels to keep the European look going on the outside. The are all 18x9.5. It is in dire need of a Full alignment to adjust the camber. I'm aware.
The second thing I should note would be I ordered a genuine Vertex hells racing steering wheel from Vertex Japan, and it took around 4 months to get made and get here. I'm very happy with it, but am having trouble getting the horn button to fit and work with the nrg quick release.
Third thing I have attempted to install are the carbon fiber side skirt extensions that were provided by DTM Fiberworks. I have installed one side and am waiting for some more time to install the drivers side. I will try and post pictures of it the best I can.
Last but not least I did install a short shifter from enjuku and a Tomei shift knob.
Next week I plan on spending some time to install a coolant swirl pot to help keep those coolant temps down a little more. And I also have ordered a new turbo exhaust housing that is a little bit smaller A/R size to help with turbo lag. The lag is something that is really killing me. You can tell in the videos it takes a while to get to boost but when it does it pulls soooo hard. This turbo was meant for top end. Will post an update when done.
Sooo here I leave you with some current pictures I took of the car today after I washed it. I realized I never posted many interior pictures. The leather Vader seats are very nice for their age. I also took a couple videos
s1208
[YT]pzFWCRkALXY[/YT]
[YT]9SJ94s69dfg[/YT]
[YT]rYMWH8LZ7UM[/YT]
  • Like 4
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
