Why? It only has a tube running through it for the driveshaft...
I would presume it would be fine. Any reason it wouldn't?
There is the diff housing thingo but does it matter if it is just sitting there?
Does it hit something?
p.s. 2 G U UP2, I thought the car in your avatar was some weirdo VP Commodore... LOL
https://www.sau.com.au/forums/topic/46508-speed-issue-14/#findComment-946293
you have to weld up the holes on the sides and might as well add baffles while its off or swap it for an RB25 sump and modify the pick up. im doing the conversion atm.
omg please i am no commonwhore driver, but after driving my mates VY clubsport all that torque is gettin to my head lol
https://www.sau.com.au/forums/topic/46508-speed-issue-14/#findComment-946668
oh and I want a Type 25 STi.... *drool*
hmm i could have sworn this was a SKYLINES forum....hhehe :jk:
yeah i love the boxer engine noise........but today i got told that tuned length manifolds actually get rid of the noise....and the boxer rumble is cause by turbulence in the manifolds.....
either way i still like it !!!
https://www.sau.com.au/forums/topic/46508-speed-issue-14/#findComment-946752
tuned length manifolds decrease the rumble but they do not totally get rid of it.
ive heard man WRXs with these manifolds and they still sound like WRXs.
when i saw EVLR34 at CRD i could of sworn it had a 13B in it lol
that car has one of the lumpiest idles i have ever heard
https://www.sau.com.au/forums/topic/46508-speed-issue-14/#findComment-946952
anyone remember that green forester a few issues back? I saw that on the road yesterday, the damn things quiet as! I've never heard a modded boxer with such a quiet exhaust.
lumpy idles > *
https://www.sau.com.au/forums/topic/46508-speed-issue-14/#findComment-947475
that letter from the Charade guy is funny LOL... he's definitely trying to pick a fight... I find him perhaps quite dellusional while writing the letter or terribly drunk... unless his charade is not stock and perhaps got a stroked V8 supercharged drag monster in it, I'd say the guy is a tool.
PS: Isn't a Charade is made by Daihatsu? And where does Daihatsu comes from.... ? :wassup:
https://www.sau.com.au/forums/topic/46508-speed-issue-14/#findComment-948456
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
    • I'm mark from Idaho.
