So I obviously gave up on the MINE'S ECU & have started down the Haltech route.
Here is a link to the start of the install & pics of the parts I chose from reading this forum & from member suggestions...
Including
RACEWORKS 725cc injectors
Haltech Platinum Pro plug and play
Boost solenoid
Walbro 255 fuel pump
Adjustable cam gears OS GIKEN
Tomei PonCam ProCam upgraded cam shafts
in 260 9.15
out 260 9.15
Rocker cover gasket kit
Autech catch can
Air intake mod
100k service kit including Timing belt
Water pump
ITS DYNO TIME...
So will be about this weeks progress & the outcome.
  • Like 1
https://www.sau.com.au/forums/topic/465091-stagea-260rs-autech-haltech-upgrade/
Well all done & I'm more than happy from 164KW to 297KW atw
On Dyno
DYNO graph
And as a bonus it has a great lumpy idle with the new cams
Idle
During the process Jezz found not one but three exhaust restrictors one before the CAT & both mufflers
Restrictors
Cant wait to pick her up...
  • Like 2
Does anyone know if Yu can get badges made? I would like a badge to go on the front grill on the space left for the Autech Version badge as it's the only spot that looks like something is missing. Any thought or suggestions?
Well been driving the car for 2 weeks now & it is a different beast, it is pure driving pleasure the power the sound it's fantastic.
I can't recommend DVS TUNING in Somersby enough, Jezz knows the RB's inside out and is a whiz on Haltech ecu's
He stuck to the quote & it was done on time. I'll be back when it's time to build a second monter motor to drop in the Stagea.
I've done a few more small mod & tidy up jobs since the tune...
Replaced the soft rubber seal around the air intake that seals against the bonnet.
Removed tidied up & spay painted the acoustic dampener under the bonnet with matt black calliper paint.
Added a huge deep cycle second battery in the back with a 800watt inverter with a RedArc smart controller system for charging camera, gimble, & drone batteries between jobs.
And I'm in the process of ordering Project Mu NS4000 brake pares front & rear as the one that the car came with must be track pads. I can't even get the abs to trigger no matter what when the are at normal temp & they have left hot spot deposits on the Nismo rotors I'll have to get skimmed off.
Jezz worked out that with every exhaust restrictor he removed I gained about 25KW so all up about 75KW AWESOME!
  • 1 month later...
  • 1 month later...
On 31/07/2016 at 7:23 PM, flavzz said:
Great result mate, very clean looking 260. Any plans to take it to the track/strip?
Not at the moment it is just too pristine of a specimen to bash around its like driving a brand new car.
  • Like 1
  • 1 month later...
Project Mu pads fitted & make a huge difference & no dust much better braking but still needs attention maybe the rotors skimmed & the system bleed with fresh dot5 fluid. I also found a genuine instrument cluster from Montreal Canada that has turned up so my tachometer reads correctly. I'll be fitting that this week with a fresh set of super white led globes. Awesome find, now I won't have the blacked out auto trans lights.
I found a genuine front grille Autech Version badge. Looks great but expensive but it was a blank area that looked like it needed a badge. I also added some cheap nismo badges front and rear as sacrificial offerings to keep the idiots away from the genuine ones.
    • I believe Unimog is the only vehicle that has it (from the manufacturer). I haven't seen aftermarket permanently connected kits, but I haven't looked either.
    • Ha ha ha, can't overthink when exhausted... Oh how I wish I had that power! I can be absolutely dead set shot, and my brain will still go "we need a good 3 or 4 hours to just think about everything and anything before you may sleep... My biggest thing is making sure I give myself enough sleep. I don't operate on even 7 hours of sleep! I attempt to give my body 9.5hours sleep a night to be able to function. I don't sleep the whole 9.5, but I need to make sure I offer a big window. I also take a single supplement, which is to help with long term health, and fighting inflammation, and I notice it helps massively. Especially me sleeping, and just less "achey" in the body. Have also kicked sugar, and gluten. A majority of people with ADHD don't go well with gluten. It causes a really interesting natural opioid overdose in the brain, which causes bodily issues and sensory issues.
    • Yeah that's what I meant, permanently connected not manual
    • Yep. But typically that's just run a hose down to the tyre while stationary.   Oh and the Unimog will automatically air up and air down tyres from the onboard computer for you too.
    • There was a good video somewhere, maybe Kurzgesagt that linked physical activity to ADHD/Anxiety/Insomnia etc. Basically the body WILL spend energy doing something if you don't spend it doing anything physical. It isn't fun, but I personally have noticed I've never been overthinky, or unable to sleep if I'm physically exhausted from doing a lot. The musings around it seem to indicate that this is one of the reasons/mechanism that physical activity improves mental health/wellbeing etc, by more or less not using that 'extra' energy to overthink, be anxious, inflammation, etc. There's also the fact that every obnoxious exerciser ever says it's great and helps which is extremely annoying. Like people who say the same thing about travel being the best thing ever. I mean, they clearly are, but blah. I started doing a LITTLE myself (think 3x15min per week) and honestly did notice the benefits, aiming at life quality when older. Which is sooner than you think. Getting something into your routine that you can actually make a routine has helped me at least. This post brought to you by procrastination between sets.
