Pay more for a npc but it's worth the money ten fold. Spoke to my exedy rep and either the pressure plate or clutch plate are made by them I cannot recall.
Would not recommend another clutch as it's by far the best "upgraded" mod that still drives like stock.
For me that's over heavy clutches, locked diffs and bullshit noises I love mine to pieces.
Knowing now I can limiter drop it hard I have ultimate faith in it.
No
Mine failed after about 8 months with 250rwkw
NPC is much better. Never ever had a drama. Got it rebuilt when I put my new engine in but that was only to extend the life. Still looked great after 3 years
Confirmation bias, I've installed more than I can count and all of them have been fantastic with zero issue.
Homo pink junk.
Needs to be at least Exedy Sports Organic, or Sports Ceramic (silver pressure plate, made in Japan)
Why? Mine held 370kw launches all day every day.
I got an exedy cushion button because they were 'the clutch to have' for city driving etc when you had a bit of power
I almost never did anything abusive to it and one day driving home from work it started slipping in 3rd.
NPC were great to deal with, spent 20mins on the phone helping me choose the right clutch for me and got it all sorted same day, had it in my hands 1 or 2 days later. The clutch has never slipped, the pedal is lighter and I'm making alot more power than before
So I guess I am just bias and noone should listen to me?
I've been there and done that. Im only bagging out one clutch as well btw. I know the hhhhdb clutchs or whatever they are handle some power, but i bet the pedal makes your leg alot sorer than my clutch
You sure it's not Sports Organic or Sports Ceramic? Because the pink pressure plate ones are a croc of shit. Exedy modify the oem pressure plates then spray them pink.
Only the sports range is a silver pressure plate that's made specifically for more clamp.
I doubt that pink rubbish is holding 370kW, I've cooked one with less than 240kW on my old R33.
I have Exedy Extra HD Cushioned Button, 290KW, plenty of hard launches and plenty of clutch kicks 20,000 kms later and it still feels fine. Still doesn't slip at all on me despite the abuse I've given it. I only went Exedy because I had a hard time getting a hold of the guys at NPC so I gave up.
I had an exedy HD organic on my s15 with 220rwkw. Held the power well but after 6 months had problems. After driving for half an hour, couldn't shift gears properly. Pulled it apart, clutch disc was almost new still, everything looked OK but pressure plate was farked. Pink one. Never again, now running NPC organic in the 33. Happy days.
  • Like 1
Homo pink pressure plate
I had one of those cushion button in my gtst and it was the worst clutch I ever had, the friction point would change as the car warmed up, it felt like it never fully released cause the box felt really notchy and adjusting it didn't help
Got one in mine now. Exactly the symptoms and problems I had for the first 5 months. Better now though so probably means I am up for another clutch soon, just wait and see.
I also HAD the same problem - It went away after I pulled the gearbox off last time.
If I was to do it again I would go NPC
Edited by kingtube69
FWIW.. NPC actually uses Exedy parts :)
Exedy Pink = gay
Exedy Silver = good
NPC (Which is just Exedy) = bettererererer
You are right it was the silver pressure plate, and I should correct myself and say that I have installed numerous cushion buttons WITH the silver pressure plate.
I assume a lot of you guys got the one with the pink pressure plate? I haven't heard of any of the silver ones failing so far.
    • Given you already have the engine cross member to match and likely gearbox mount to. The SR20 has a head start on the RB in this case. They handle GREAT with an SR20, lots of fun.   One I did back in the day
    • have no doubt and wanted too trust me and may regret later not necessarily worried about weight (would be 8 kg ish total) it was more the $$ to do it properly is about $6 - $7K in hardwear need long 310mm stroke jacks etc - plus install and call me whatever im not doing it myself even if wanted too cant weld etc  - thats $10K installed vs fraction of that cost while Ive spent some money on this POS I actually really dont like doing so unless its got a large chance to make me go faster 😁 hey in still carting this things around on a 15 yr old rusted open trailer so I can spend on racing not buy a new trailer to look better the manual jacks Ive had done are heavy and take space but are transportable and usable anywhere - taking or organizing even compressed air let alone nitrogen which is more whats needed coming from Perth to Winton or Sydney or the like honestly just adds to my brain headaches/ hurts of organisation also ha 15 mins job will get down to 2 - 5 min job vs 1 min job for airjacks - all tradeoffs I spose
    • Purely out of curiosity, how do you know all this @dbm7? Do you work with automatic gearboxes professionally? This goes way way way beyond "I've had an automatic Skyline once and did some mucking around"
    • I'll just reiterate that it's best to do all the wiring diagnostics, before even thinking about buying replacement solenoids ~ that is, be absolutely sure the solenoid is bad.....ie; bad connector(s), rodents chewed through a wire, etc etc. If you don't so this, you can fork out all the money for solenoids, only to find something else is wrong (this'll make you cry if you pull the valvebody only to find a broken wire is at fault... ...some more glue on the solenoid packs -- this is the RE5R01A shift solenoid assembly.... ...these are all shift solenoids ~ ostensibly they're the same as the shift solenoids from the 4-speed auto.... ...this is the RE4R01A solenoid set... ...with these, you have 3 shift solenoids attached to the plate, and the separate solenoid is the EPC solenoid (line pressure control) -- with both designs, the TC lockup clutch solenoid (also PWM so they could slide the clutch shut), is located on the lower valvebody half.... ...(story time)...back in the 90's, it was a common fault that the EPC solenoid (or TC-lock solenoid) would fail, but Nissan only sold them as part of the assembly (think ~$350 at the time) ~ thing was, Isuzu also used these boxes in light commercials, and you could buy the PWM solenoid as a separate part, so it was possible to buy/use that solenoid (around $65), and make it fit (remove the circlip, fit to old plate and deal with wiring)...making it a more cost effective repair. I've not seen the RE5R01A shift solenoid assembly, but with the 4-speed RE4R01A it was possible to hack/fit a single shift solenoid onto an other working set, using a donor solenoid from another set with failed EPC....(by rights the whole set should be replaced), but it ends up being a question of how much life is left in the box itself ; sometimes it's a viable repair to fix one solenoid, just to get another 100k of road miles out of it before it needs first overhaul...other times the box is that old/worn, you're as well doing first overhaul and replacing the solenoids and starting fresh... What Nissan did here with the 5-speed, was relocate the EPC solenoid to the lower valvebody (next to the TC lockup solenoid), and stuck the direct-drive clutch solenoid (for the extra gear) where the EPC solenoid used to be on the 4-speed....I can only imagine they did this for serviceability ; the PWM solenoids are most likely to fail, and it's a doddle to drop the pan and change these out (as opposed to dropping the valvebody itself to get at a top mounted EPC)... ...also keep in mind, that some BMW 3/5 series & Mazda (and maybe some Ford/Mazda rebadges, not sure), also used the RE5R01A box under a different name/part number...not saying parts availability is any better, but sometimes it helps to know this when it comes to NOS floating about in the EU.... HTH
    • FWIW, air jacks are actually pretty light and simple to add, they are just 4 hydraulic cylinders (often at the main cage A and C pillar points) and an externally accessible airline  - they make quick work a breeze
