Just got a quick question, might seem abit dumb but i have searched the forum and have not find anything too much related to my question.
As the title says: Does an N/A engine with a turbo installed definitely need a VASS to pass RWC? As under my awareness there is no mention of that in the "Engine" section of the RWC requirement from Vicroads, while in the "Modified Vehicles" section it seems that as long as it does not affect the vehicle's handling, structural integrity of compliance with the standard for registration, then it wont need a VASS? Is there sort of like a grey area in this context of whether a VASS is needed?
Also because the engine is an N/A, does it mean that i also HAVE to past the ADR emission test too?
If there is anyone who know any RWC place that can help me pass an N/A+T without VASS feel free to message me, as that would save me the trouble of un-turboing my car and putting the stock manifold etc on which i might not have to do now.
Thanks in Advance!
hmm do u mean that if I put the "Rb25 NEO" cover on top they might not realize that the car is turbo'd?
Hopefully they don't realise or care that its meant to be a non turbo. Can't hurt to try[emoji6]
I've had 2 canaries while my car has been turbo'ed for too low and a few other things while on my P's, never for actually having a turbo (this was back in the power to weight days, and each time I convinced the officer I was under the power to weight) so when I had to get a RWC then go to Vicroads they all just checked the things that were marked on the canary. No one ever questioned should the car have a turbo, were you picked up for having a turbo?
    • Old Son, did you re-use the Holden ABS in the new shell or try a different module?
    • Yeah, nah. I had the actuator rod off it today. The arm will not move at all. Neither out, nor in. Yeah, you'd think so, but I've been thinking about that. Even when the actuator rod fell all the way off at the beginning of this saga, it would build more boost and faster in lower gears than it would in higher gears, and you'd think that that was the opposite of what should happen. But I strongly suspect that there is a thing with the gearing getting the revs to rise faster, that there must be some transient effect with the gas flow rate rising quickly, that you don't get with the more steady state case of the higher gears. Keep in mind - the gate is not shut in either of my weirdnesses. So things are not "normal". We normally think about a turbo spooling up (below the wastegate target) with the gate shut. I have all sorts of mental models running now where the gate is a little bit open, and having it stuck open allowing gas out while it should be going through the turbine has all sorts of weird effects (in these mental models). I'm thinking in the higher gears, the ex mani pressure builds to the point where enough gases spill out the wastegate to just prevent the pressure rising much more at all, or just creeping up, all the whole the revs are increasing and getting closer to the point where a gear shift becomes necessary.
    • Is it possibly wastegate actuator itself is sticking, or even the rod to flapper? Otherwise I reckon things are getting a bit rusty/worn   Also odd it won't boost in 3rd to 5th, but will in 1st, I'd expect the other way around with it slightly open as there's more time on your way to redline for it to spin up
    • Does anyone know ow what these two plugs are for and if they should be unplugged? Just put the dash back together and can't remember if these were plugged in before or unplugged! (Blue and white plugs) 🤦🏽‍♂️
    • Did some FASTing ...got the impression that the actual part# was a moot point ; seems all of these hardlines for coolant are discontinued/NLA... like, I take it you're after the hardline that bolts onto to the manifold...that's NLA according to amayama & nengun .... ...just to clear up some confusion, they typically mounted the AAC valve to the intake manifold somewhere near a coolant passage, so the body of the valve heats up & holds it open when engine's up to temp - no coolant flows through the valve, it's a mechanical, thermal connection.
