Hi guys, when I bought my R33 gtst it had a stalling issue if I came up to the lights and took it out of gear or pushed the clutch in (only happened sometimes). From advice I had read, I decided it was the IAC which I preceded to clean the gunk out with carby cleaner and reinstalled.
Stalling issue fixed.
I marked the screw before removal on the IAC and set it back to this. Car idles at 900rpm warm and about 1100rpm when cold (approximately). On the sticker under the hood it says rpm should be 650rpm.
Have I set the idle too high?
The car now rev hunts on idle, it only does it sometimes. It will rev from 900->700->900 repeatedly, is this normal? How can I fix this?
Will this effect the timing on the car? I am in the process of changing the timing belt and I read on here that the idle can change the vct which changes the base timing?
I have lined all marks up with their factory position, I have ordered a timing light and plan to make 100% sure the timing is correct but the rpm changing the timing has confused me (doesn't it only usually do this at a certain rpm where it changes the camshaft phasing like vtec yo?)
https://www.sau.com.au/forums/topic/465147-r33-rev-hunting-issues-timing/
650rpm I find is too low for the idle. I always set mine at about 800rpm
If your IAC was indeed clogged with gunk, setting it back to the same spot will not give you the same idle as before. You will need to do a proper idle adjustment to find the correct idle speed
Adjust as follows (The main bit to look at is near the bottom of the screenshot)
In addition to this, I would reset the ECU (if you are still running stock ECU). I had an issue with idle when I installed an Atmo BOV then changed back to a plumback where the car didn't want to idle right. Messed with heaps of stuff then reset the ECU and that seemed to fix it. Easy to do, unplug battery > stand on brake pedal, turn on lights etc (basically anything to drain the residual power in the car), also wait about 15mins or so after this if you want to be completely sure > plug battery back in > Start car and let idle for a while. Forget how long it does its self learn thing. Think its about 5-10 mins
Report back after doing these things
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
