SECOND HAND
R32 GTR, Wrecking - ALL PARTS
Roll cage, Cusco saftey 21, 6 point roll cage, padded, suit R32 $800ono
Kaaz Mechanical diff, suit R33 non a.b.s $1000ono
HKS Hyper exhaust suit R32 GTR $700
Nismo G-Max twin plate clutch and flywheel, near new $1000
R32 GTR Rear wing, and Nismo R32 GTR wing $400ono
Nismo 400R front and rear bars, $500ea
R33 Aero Mirrors, Electric $600ono
R32 Stainless front pipe, $500
GTR polished intercooler, $850ono
R32 GTR bonnet, mint cond, $1000ono
BRAND NEW
Blitz Brand new Spec-V & NuR spec bolt on exhaust, $1050
Blitz BOVs, Brand new, universal $330
Blitz LM air filter kits, brand new in box suit all skylines $150
Ask for prices on Blitz intecooler kits.
Ring 0419118258 only, DO NOT PM
https://www.sau.com.au/forums/topic/46515-skyline-performance-parts/
Hey
I sent you a SMS regarding Roll Cage, I never got a answer from you.
Can you please send me pics of it with details on what needs to be modded, removed, cut etc for it to fit in.
[email protected]
Thanks
CHASP
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
