Hi Guys,
We are cleaning out a shed full of RB Parts.
RB26 blocks $400.00 Each from standard bore to oversize. 3-5 to choose from
RB30 Blocks A8 Turbo $400.00 Each from standard bore to oversize. 3-4 to choose from
RB26 Cranks - Longnose $400 short nose $175
Arias RB26 Standard bore (86mm) Forged Pistons (set) good condition $300.00 ony need rings.
CP Pistons For a RB30 Block and RB26 Head (set). To Suit 86.5 oversize bore. with rings and pins $500.00
Spool RB30 Rods good condition (set) $500.00
Mahle for a RB30 Block and RB26 Head. To Suit 86.5 oversize bore. 5 out of 6 are band new 1 got damaged on the machine cutting clearances for the oversize valves. $400.00 - it will cost $200 for 1 new piston the set is worth $1200.00 new.
HKS Pistons for a RB26 87mm with rings and pins (set) $400.00
ARP RB25 Head Stud Set - $150
Greddy RB fuel rail $50.00
New Sets of Bearings
heaps of other stuff
twin turbo dump pipes HKS and Stock 34 GTR Dump Pipes
I can freight Australia wide. location Newcastle NSW
contact Adam - 0449 664 330
  • 5 weeks later...
  • 3 months later...
    • How fast are you doing the downshift? 4th gear was revised multiple times until 1998 to fix this issue. Synchro clips can fall out, synchros can wear. Most likely you're looking at a new transmission unfortunately. If you need to limp it until then double clutch downshifts into 4th.
    • Sorry I was being harsh there, but am I wrong? You can buy a M340i easily, and there's loads available second hand. A lot more workshops modifying them as well. How about getting parts for them? Don't get me wrong, I'd love a 400R, even a 4cyl (I looked at a few V36s before buying my shitbox BMW). Sadly Infiniti died in Aus and we're stuck with importing them as niche vehicles. Supply and demand
    • Probably straight swap for an R32 GT-R? lol
    • Yes I think we changed out the transmission fluid as I had a leak last year so we changed out the seals also. Need to check.    I should have said just change from 5th to 4th gear … down shift. There’s a grind.    I have a new clutch X clutch … but as I said all the changes in other gears are fine.
    • Change the transmission fluid. I would try Motorcraft XT-M5-QS if you have it in your area for a reasonable price. Also, double check your clutch is fully disengaging. If you are not pushing the clutch pedal to the floor fully for every shift now is the time to start. Make sure the clutch is fully bled. The damper line requires two distinct bleed points to be purged of air or it will not disengage the clutch properly. If either hydraulic cylinders input or output are losing hydraulic pressure in their seals/leaking you can have problems like this. If you've ruled out everything else then the most likely explanation is the synchros are worn and you need to double clutch the shift or rebuild/replace the transmission. The transfer case is discontinued FYI so you may want to rebuild it while you're in there too. If the chain stretches past spec it can do a ton of damage.
