Hi Guys,
We are cleaning out a shed full of RB Parts.
RB26 blocks $400.00 Each from standard bore to oversize. 3-5 to choose from
RB30 Blocks A8 Turbo $400.00 Each from standard bore to oversize. 3-4 to choose from
RB26 Cranks - Longnose $400 short nose $175
Arias RB26 Standard bore (86mm) Forged Pistons (set) good condition $300.00 ony need rings.
CP Pistons For a RB30 Block and RB26 Head (set). To Suit 86.5 oversize bore. with rings and pins $500.00
Spool RB30 Rods good condition (set) $500.00
Mahle for a RB30 Block and RB26 Head. To Suit 86.5 oversize bore. 5 out of 6 are band new 1 got damaged on the machine cutting clearances for the oversize valves. $400.00 - it will cost $200 for 1 new piston the set is worth $1200.00 new.
HKS Pistons for a RB26 87mm with rings and pins (set) $400.00
ARP RB25 Head Stud Set - $150
Greddy RB fuel rail $50.00
New Sets of Bearings
heaps of other stuff
twin turbo dump pipes HKS and Stock 34 GTR Dump Pipes
I can freight Australia wide. location Newcastle NSW
contact Adam - 0449 664 330
  • 5 weeks later...
  • 3 months later...
    • Ayooo, been a while mates. I have a s2 r33 gtst and air stopped coming out of all the top vents.   My car has always made an actuator gear noise when turning the car on but that's a different issue I think? Did searches and am at process of thinking it's an actuator or some type of motor? I see a few different actuators and don't know which one. Would be nice to know if it was the one that's under the steering wheel so the dash doesn't need to come out.
    • Hi, just checking. Did you get this stuff made by Vspec Performance and at what price roughly? Looking into (sometime later) also getting such a intake kit, and Trust as well as HKS don't make a full set like this anymore.
    • 2025 Update PRP RB30 Black and Crank Shipped from Austrailia made it and was sent off to the machine shop. -700 to 800hp Service was done to the Block, which included: Inspection Prep and Black Brace to convert engine to 4wd oil Pan  Crank Fully prepped for 1000hp PRP RB30 timing belt kit w/ ALL options Nitto Pistons Nitto I-Beam Rods Nitto Oil Pump New OEM Nissan RB26 Cylinder Head Shipped Supertech intake and exhaust Valves over-sized Kelford 272 cams Mild Lift Nitto Headgasket All of the machine work is completed and next step is assembly and dropping in the new motor.   Upgrades (Changes) from the previous build: Engine Management - no longer using ECUMasters. Haltech Platinum Pro Turbo - Went from twin HKS 2530s with upgraded wheels to BW362SX-E Fuel - 1000cc injectors to ID1430x Single in tank Walbro 450 to Radium External Surge Tank w/ 2x Walbro 450s     I am looking to be back on the road by the end of summer. Wish me luck! monthly updates should be coming!
    • Realised I never posted this , also I never got a price
    • I'm glad to hear you've joined the SKI club. Spend the Kids Inheritance.
