Hey Peeps,
I forgot I had these.
Up for sale is a brand new pair of REPLICA Bride Maxis III Low Max fixed back bucket seats with red graduation fabric and kevlar shell and universal rails.
These were purchased a while back through a group buy on here organised by Longz.
Unfortunately I am a too big for these, much to my disappointment.
I am 6'4" and 100kg with broad shoulders and a 34 - 36" waist.
Would suit someone with a thinner build.
They are still wrapped in plastic and in the box i pick them up in.
Were only taken out to test fit my butt and take photos, then wrapped back up and put back in the box.
Paid $850 picked up when i bought them.
Selling: $800 posted anywhere in Australia (or pick up from Wollongong if you like).
Would rather sell as a pair.
Will only consider selling separate if both are spoken for.
Mate you are 75kg at best! Haha
Standard 32 seats too small for you as well in guessing?
Haha, Its cause I dont even :)
Fortunately I still manage to fit into the stockers.
Never lift!!
Do you have a good set of seats?
I have a pair of Sparcos (but i still need rails).
  • 1 month later...
13 hours ago, NoticeMeXavier said:
Just curious, first time buying bride seats. If I take them off you would these just bought in or do I need other stuff aswell :)
With the rails being a universal style, they will need a little modification to bolt into the standard position, or you can buy different rails to suit the application which would be a direct bolt in.
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
