The Barra engines are the go, only need to do internals if going 600+hp, they are a high torque motor and a lot of fun, power glide is definitely the go.
I have seen it done but can't remember the guys name.
Only real downside is it won't sound like an RB
Not only do they not sound like an RB. They sound like absolute dick.
Yep definitely don't have the same aggressive scream like RB and 2J its like the tone is stuck inbetween a 6 and 8, hate there sound but awesome performance.
Sounds like you have dicks in your ears.
Some of the comments in this thread are hilarious.
Take a look at a dyno sheet from a mildly tuned Barra 4 litre, and you'll soon realise why they would smack an rb25 like a redheaded step daughter. All while making peak power at about half the revs of the rb25, and hold it to redline.
dont let common sense get in the way of a good internet argument lol
  • Like 1
Interesting. I just got home from a cruise with some mates.
My mate with a tuned Barra got pissed on by an 34 tonight.
That's right, the guy in the 34 had time to stop, flop out is dick and piss on my mates car as he drove past.
Is that hilarious enough for you.
Because I find it bloody funny.
Edited by XGTRX
    • A few more recent pics
    • full send the cnut, do this   fark the wrapping and/or stick on siet. These guys are the ones to go to: https://www.realthermo.com.au/
    • Just had a look, they don't. Fuelling on the base map is purely alpha-N, and the ignition table is MAP. Remember it's just a base map to get the car moving
    • Hi everyone, I’m Dave from Canberra. Here's a few pics of my 1992 R32 GTST coupe which I imported back in 2006. Only mods so far are HKS Hi-power cat back exhaust, K&N filter, ATC Volanti steering wheel, Pioneer stereo, amp and sub. This was my daily driver up until 2015 and sadly hasn’t been driven at all in the last 5 years due to marriage, work, and kids taking up most of my time and spare cash.As such its in need of a bit of TLC and one of my goals for this year is to get it back to running condition and maybe look into club/historic rego. I’ve joined SAU so I can ask a few questions along the way (although I promise to google Current Problem +SAU beforehand!)
    • From talking to the mx5 guys the NC doesn't actually need bonnet vents like the earlier NA and NB models, due to a better designed cooling system and undertray design There's plenty of them used as street cars and weekend track toys running anywhere from around 170 to 250kw with stock non vented bonnets, I initially was going to get some bonnet vents, but, as they are not actually required, I'll put vents on hold for a while and just monitor temps, though I do need to get something to actually monitor engine oil temps though, coolant temp can be pulled from the OBD2, but the oil gauge in the car is not actual oil temp, it is only a calculation based off coolant temp and RPM ☹️ They do recommend upgrading the radiator, which I have already done with a triple pass, and the only other thing they recommend for a street car is heat management, like I talked about above to protect bits in the engine bay from radiant heat, and to either replace the nearly 20 year old plastic coolant expansion tank, which I have done, or get a aftermarket alloy jobbie for some bling They did also say that if I wanted to track the car on occasion a oil cooler and sump baffle would be required, and as I already have had a sump baffle installed when the engine was out......... I'm going to get a oil cooler with a thermostat....... just in case I do eventually track the car, but probably not, but still maybe...🤪
