It's been AGES since I've last come onto these forums, but I figured this would be the place if any to put this up...
Clearing out my storage boxes, I found my brand new blank Nismo Design Key that I bought from the Nismo Omori Factory in Japan about 10 years ago.
It's completely un-touched, and ready for cutting.
Those who have been looking for one will know how hard these are to find, even more so in a blank, un-cut state.
I have no idea what it's worth today, but using a similar listing on eBay (where they are asking for $680), I'll put mine up here for $500 neg.
In no rush whatsoever to get rid of it, so don't waste your time with low-ball offers... It's been a while since I've visited SAU, but if you look at my post & thread history, you'll see I was a very active member (NSW Exec at one stage).
PM / Email ([email protected])
Hey mate, tried to send a PM but looks like your inbox is full.
I'm interested in this, PM me if you could. Cheers
Sorry about that, didn't even check... inbox should have space now.
  • 2 months later...
  • 1 year later...
21 minutes ago, dan the man said:
Still got it? Cash waiting
Yep... Just dusted it off the other day, these should be as rare as world peace these days, will need to see how many (if any) are still for sale and for what price.
18 minutes ago, niZmO_Man said:
At least $1,000 USD
Thanks.
Due to a recent resurgence in interest, I've taken another look at what's available on the market... there's a grand total of 1 going on ebay for 640GBP which is well over $1k, another forum post suggests 120,000 JPY is not uncommon on Yahoo JP if and when these come up.
I can't seem to update my original post but the price is now $800... expensive for a blank key yes, cheap for a true collectors item and one of the few things that will continue to go up in value if left un-touched.  As such, in absolutely no rush to sell :)
  • 11 months later...
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
