Hello all,
Have just joined as I'm looking to tap into the vast knowledge here, starting with my spoiler. This is my first Skyline and therefore I'm trying to get my own information up to speed.
Quick details on my car are here: http://www.sau.com.au/forums/topic/465234-new-from-the-uk/
I've searched here and online and found the following two thread but neither really fledges out the details and also how to fix it. Mine is working for the most part, however it doesn't work automatically. It will just permanently come up as soon as the handbrake is released, and will refuse to stay down when the down button is pressed, I think this is because the down button won't "click" into place.
http://www.sau.com.au/forums/topic/294465-spoiler-up-spoiler-down-buttons/?hl=front%20spoiler
http://www.sau.com.au/forums/topic/339944-help-with-these-two-buttns/?hl=front+spoiler#entry5557440
Here are the button & it in the up and down positions:
I've taken the button out (when I was attempting to fix the odo) and it's defo part of the original car;
and here's the English manual blurb on it
Would anyone be able to tell me if there is a place which gives more details on it so I can return it to full working order?
Does anyone have a wiring diagram for it, I couldn't find one in the workshop manual I have got hold of.
Thanks
Tommo
Haven't seen an R33 one, but the R32 and R31 came with them as well. I have no knowledge of the R32 and R33 ones, but the R31 ones automatically folded up below a certain speed (came down after 70 km/h IIRC). You had to by-pass this (manual override) to make the autospoiler stay down.
https://youtu.be/6Q9AcL4rPhw?t=4m52s
A quick search: http://homepages.vodafone.co.nz/~lakewood/Skyline/Spoiler.htm
I think the part number for the switch is this: 2512015U00
http://nissan.epc-data.com/skyline/ecr33/3901-rb25det/electric/251/25120/
Wow thank you for that, reply is just perfect. I'd searched for so many different names for it and had missed "Active front spoiler"! I have a feeling my switch could be part of the issue with mine as like the guy in the link say his "down" button wasn't latching. With the car stopped and the handbrake on the spoiler will move as intended so I don't think there is anything wrong with the actual function of the spoiler. Will ask my importers parts desk to see if they can get hold of one! :)
Also that R31 promo video is just the best thing ever!
    • Hmm. Yes. I should have been clearer. 1000s for Haltech, for extra headroom. 725s for Nistune. You might even be OK with 640s, but if the possible power ends up much more than 300 rwkW you will run out of headroom on the 640s. That would probably be OK and a signal to not push it to that sort of power with Nistune anyway. At that level you probably do want to be thinking about engine protection functions. Oh, and all of that presumes 98 only, not E85. Well....the 1000s would allow you to run E85 at ~300rwkW territory, again, maybe sort of running out of headroom. Hard to tell with E85 - depends on the tuner as to how rich they like to set it up.
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
    • Haltech fanboi reporting in. Buy the Haltech!
    • You can try shoving a borescope down there to see what's up.
