My soarer is loud as f**k with its 3.5" system
Has a big hooker aerochamber at the back and a custom mid muffler (its small cause f**k all room with a 3.5" pipe)
What mufflers are you guys using on the quieter systems?
4" dump, 3.5" cat, 3.5" mid muffler, 3.5" massive 18x12x6 rear muffler.
Both just off the shelf straight through glass packs from an exhaust shop, did a little shy of 400kw just fine on a 35r years ago, dyno sheets somewhere in the rb30 threads I believe.
Low frequency components (~120Hz) seem to be the main frequencies transmitted into the cabin and the source of exhaust drone. An uninterrupted exhaust diameter from front to back (think 3" straight through) seems to be prone to resonances around low frequencies. The only way to break up the low frequency resonance is to make the length of the constant 3" section shorter. The way of doing this is by changing the exhaust diameter in the middle with a full size centre muffler. This is why basically every quiet exhaust has a full size centre muffler. A hotdog resonator in the middle won't do much, they are too small to change the pipe tuning.
I had a Fujitsubo catback in my R33 and it had full size centre and rear mufflers, very quiet system. I'm about to buy something very similar for my R34.
Mine is 3.5 to the back of the cat and 3 through two large strait through mufflers to atmosphere .
One thing you can do is to put a "soft" part in the system to isolate engine vibration from the exhaust system . Most of you would have seen those spring loaded carbon ring and cup joints many transverse front wheel drive cars have . Because the across car engine rocks back and forth under acceleration (torque reaction) the exhaust can't be rigid or it'll act as a tie bar .
This clever joint allows engine movement whilst staying sealed , it also isolates to a degree engine noise and vibration .
Big diameter tube is very rigid and tents to transmit lots of vibration and noise into your cabin . I got my one off exhaust fitted with one of these spring loaded cup joints behind the cat and roughly where the gearbox exhaust hanger is . That way the front of the exhaust system is supported the length of the rigid engine and gearbox but allows movement south of there .
A bit of mucking around but it does work .
A .
A .
Is it the same as a normal flex joint?
Noise reduction is more important than ever with the laws being the way they are , which is why standard cars now sound like vacuum cleaners .
That "soft joint" also takes a lot of load off your turbine housings bolts/studs and very likely the manifold itself .
A .
No they are actually better things than the bellows type ones with the braided wire outer covering . The braided ones don't like really high temps and the word on the street is that they expand inwards creating flow restrictions .
With the spring loaded "cup" joints the only things that can fail are the carbon ring or the two bolts and springs but I've never seen the fasteners or springs give up . The other thing is that they are really simple to take apart and the usually the only consumable part is that carbon ring - which if in fair condition goes straight back in .
I had to insist the exhaust place that made my system fit one but it was well worth it . Truck exhausts sometimes use these kind of joints so big bore parts shouldn't be hard to get . Some better exhaust places may even have the press dies to make them .
The obnoxious hum/buzz/drone in aftermarket exhausts is often the exhaust pipe and mufflers vibrating/resonating particularly if the engines torque reaction is being restricted by 3 or 4 metres of big bore tube . The engine and gearbox mounts are there to dampen engine/trans NVH , but hang a long rigid tube off something solid like a manifold and or a turbo and you can expect noise and vibration issues .
My old Subaru RX Turbo had a 3" dump pipe and 2 1/2" behind the middle muffler , think 1800cc flat four with small port prehistoric heads and a little GT2554R turbocharger . In legal rally trim (Grp A cams/pistons/computer/exhaust) these engines put out a great snappin 190 hp at the flywheel .
Really that exhaust was too big for what I was doing but with straight through mufflers and one of these joints in the factory position it was NOT noisy - at all .
I'm not saying that these joints are a magic bullet but together with big can area straight through mufflers (no baffles) you can have an exhaust that doesn't wake the dead or irritate your cars passengers .
A .
  • Like 1
How much can the "cup" joints flex/move ? Wondering if they could be used to help line up segments of the exhaust ( making home made exhaust here.. lol )
Anyone used this style flexi joint part? post-70965-0-07561700-1466814319_thumb.jpg
Edited by AngryRB
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
