Hey guys
A mate just bought a 32 with a RB25 from a 33 running on a PowerFC. it runs and drives but has a few little issues they we need some help with.
When starting cold or hot it takes 2-3 turns of the key for it to actually start, 1st time u could crank forever and it won't start, 2nd crank it will stumble after a while, 3rd it starts up just fine
Sometimes when it's hot and restarted a few mins later it will start first go
It runs rich as f***, huge black clouds before boost and as u let off, also has huge orange fireballs as u let off from full throttle
Has very bad fuel economy
Has Z32 AFM and been told aftermarket injectors (can I get info on standard injectors so I can double check)
Input and help is greatly appreciated
Dont really wanna pay for a full retune if it's something simple
https://www.sau.com.au/forums/topic/465260-rb25det-powerfc-issues/
You cannot hope to make a standard ECU run with a Z32 and bigger injectors. The only way it could possibly work is if the relative change from stock on both the AFM and the injectors was exactly the same. Chances of that are pretty bloody small.
Best option is to take it to someone who can do the obvious stuff, like measure the fuel pressure when it's on load, put a HC or laptop on it and see WTF is going on when it is trying to run and trying to start. Which means a trip to a tuner, with minimum cost being a little time and maximum cost being a full retune + repairs if something is stuffed.
    • Lol yeah I ordered the clips mentioned and as far as the amayama diagrams go i think thats all I'll need. Fogured id ask, sometimes people's first hand experience doesnt always match up to diagrams haha, i guess I'll wing it and worse comes to worse I'll just deal with it as I go
    • Thanks for all that information I appreciate it. To answer your questions: - Yep that's what I mean. These guys are professional painters to so I must be missing something. It's a bit hard to explain. - With the primer landing on clearcoat, I make sure that the surrounding clearcoat is scuffed to 240 grit as my epoxy primer says that I only need to sand the area to 240 grit. - Yeah so similar to the first question, assuming that the paint landed on the unscuffed clearcoat because I've seen that happen. - Yep I want to prep the surface in that order. Only reason because epoxy primer will protect it from rust and I need that atm with this crappy Sydney weather. I think I was worried about time, if I try to put the filler down but screw it up somehow and I don't have time to sand it off and reapply it then need to put primer later that it might start to rust again so I wanted to apply the primer as quick as possible to not deal with rust.  - I just deleted some answers, I just realised after watching a video and what you said about looking at the data sheet, that I need to read the data sheet on the specific filler I'm using. It's possible now that I put epoxy primer first was a waste of time and need to go to bare metal lol
    • I did. I went to a suspension guy and he told me because I don't have adjustable camber arms it's the reason why my car veers towards the left if I take my hands off the wheel but if I drive my other every day car and take my hands off the steering wheel it goes completely straight. I think it's common with Skyline's. In order to fix the problem, I likely need gktech camber arms then nismo bushes since I have poly bushes atm, then a wheel alignment after that. With my car if I take my hands off the steering wheel on a really bumpy road before stopping at a light I have to hold my steering wheel somewhat tight otherwise my car will legit just go completely in the other direction quite quickly and I'll slam into something lol instead of stopping straight. I Believe this YouTuber had the same issue and fixed it with gktech arms. At timestmap 6:05 he talks about how the car doesn't veer anymore after installing these arms.
    • hello! does anyone have a schematic that shows how to test the blower motor resistor for the vac system? i believe the part# is 27761-15U00. I think the resistor is toast, but would like to be able to test it somehow before i embark on the journey to find a new one. cheers! 27761-15U00
    • I don't know the answer to this, but did you have a look at the parts diagrams on amayama.com and see what they list around it for your car? As an example this should be it on my car. That's how I would check for required clips and things like that. But, I take no responsibility for you ending up with a box full of random OEM hoses, washers and clips after going down that path a few times. This definitely has never happened to me
