Evening all,
Was driving home on the F3 (M1, whatever!) tonight and the just noticed the car 'shuddering' at around 2500rpm. Not a heaps violent shudder or anything like that, but definitely noticeable. I managed to creep my way up to 110kmph, no worries, but anytime I gave it a bit more gas and it would drop to fourth revs go up etc I would get the shudder again. I nursed it back onto Pennant Hills Road, and did a bit of testing and confirmed, definitely shudders at around 2500rpm, irrespective of higher speeds etc.
I know this is about when the turbo starts boosting, but driving the car under 2500rpm seems fine. Can hear the turbo whining per usual. No errors on the dashboard or anything, idles fine, engine doesn't stall. Thinking possible leak somewhere/vacuum lines.
Wondering if anyone else has experienced something similar to this before? Trying to narrow it down.. bit dark out there to go check lol
Car is a 2001 AR-X, stock except zorst., 123,xxx kms.
Cheers
https://www.sau.com.au/forums/topic/465267-m35-help-shudder-2500rpm/
I have a c34 stagea..i have a similar problem when at high revs..it has a shutter loses bit of power..and has a small like shutter when it idles...i think mine is fuel pump..because if i keep tank full or above half doesnt do it once...if i gets down near like quarter tank..it starts happening again...
Evening all,
Cheers
Hi mate, it sounds like your AFM has failed.
Do you have a light on the dash?
G'day Dale.
Thanks for your response. I've read about the troubles with afm's, but symptoms sounded a bit different to mine? ie no errors in the dash and car isn't stalling..? Still, afm is a good thing to have spares of, where are ppl getting theirs these days? Wrx sti compatible or is the verdict out on the cheap Chinese versions?
Btw, I took the car for a short drive yesterday. Seems the shudder/hesitation kicks in around 3000rpm now.. So much more drivable lol :P
They don't always fail with the characteristic mil light and no idle, I've had one that would only fail when the intake temp went over 37 degrees, and it would only make the car stall at idle. Everything else was fine.
The current issue doesn't seem like the typical AFM symptoms; but checking all coil plugs and AFM plug is seated properly would be a good start, and making sure all the small vac hoses are connected in the plenum and valley area.
Maybe check all cooler piping for loose clamps and possible split joiners.
Cheers Dale. Hopefully I will get some time to check it out over the weekend.
Is it blowing smoke at all? Mine had similar symptoms to what you're describing plus the smoke blowing.
mmmmm Not really.. just a normal amount of white vapour-like smoke which disperses quickly, not something I would worry about. What was the issue with yours in the end, Duncan?
Split in the silicone hose on the cold side of the FMIC, took ages to find.I think I replaced every other silicone hose before I got to that one, as well as coil packs, spark plugs, hose clamps etc. Heres what it was running like:
  • Like 1
So is it fixed or it's still missing? Sounds awesome, like anti-lag :)
https://www.youtube.com/watch?v=0QotAsFh7mc
A pressure test would have found the leak instantly.
Yes, if I'd had a kit or anyone I know had a kit I'd have used it.
Fixed ages ago, it was a pig to drive getting on to boost as it basically leaking air and over fuelling (as you can tell) at about 3-3.5k
  • Like 1
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
