Hi all,
I changed my front discs to 310 mm ebc grooved and red stuff
Planning to do the same at back
I want bigger discs for the looks of it but understand it won't fit it
Has anyone fitted a bigger disc than 310 or 296 for rear?
Do you gain much braking power by bigger disc as it has more surface ?
I also have braided lines and racing dot4 catsrol
What will be the next upgrade you do? Master cylinder or brembo calipers??
https://www.sau.com.au/forums/topic/465273-disc-size-r34-gtt/
I did fit the front ebc dimpled and grooved and red stuff
It almost crashed the other day as it soften up while doing a hard braking so either needs bleeding or something is wrong
I am aiming to get 500-550 bhp from mine and want to have a brake which supports that power
I have seen posts people using asaptor kit to use evo disc of 350mm
My question is would 310 mm with brembo be as strong to hold the car at high speed ?
There must be a reason all super cars have a bigger disc
I have the AOR Brembo Kits front and rear on my R32 GT-R. The fronts made a massive difference but the rear upgrade was definitely required to restore the brake bias.
Just factor in your wheel size as factory 17" don't clear this setup.
If you were try try to put ~350mm rotors at the rear you would need stupendously big brakes at the front. Trying to match VERY big rears with 310mm fronts would be wrong wrong wrong wrong.
You will not need to upgrade your rears until your fronts are at least >340mm.
You want us to tell you whether to do that? Surely it depends on how important it is that you have large looking rear brakes.
If you have enough brake power for the driving you do then ANY brake modification you do from this point on is completely gratuitous and you have to justify spending the money to yourself.
Pretty sure track guys run stock rears with ~350mm fronts, so don't upgrade the rears until you're running something seriously big up front. If they're not pretty enough paint the callipers...With grippy tyres the rear gets unloaded more than with street tyres.
Failure modes are: pads overheat or fluid boils. Can you describe in more detail what you mean by "soften up".
EBC reds are a crossover pad, so almost certainly wont cut it at the track. What's the boiling point of the brake fluid? Dot 4 spec is only 230 degrees. Nulon xtreme will do 280, then Motuls to 320+. Did you do a full flush or just a bleed?
tl:dr pads are too conservative, if the fluid is anything less than 280 then swap it for nulon xtreme (since its cheap) and go from there.
If you are going to get Brembos for the front presumably they will be off a GTR so you would use the 324mm rotors as well. How did you manage to spend $1000 on GTT brakes? Was that for front and rear and some exotic pads or did you get expensive aftermarket rotors?
If you were using Castrol SRF racing brake fluid that is almost as good as Motul so probably not the problem (if you filled the system with fresh fluid and bled it adequately).
Seems likely poor pads were to blame.
If you want to splash out on bigger brakes still a set of D2 330mm rotors 8 pot calipers (sold under other names as well) with Pagid pads and 2 pot GTR brakes on the rear pulled up my big heavy Stagea lap after lap with no fade.
It's still not entirely clear to me what OP is after with his brakes.
If you're after performance not looks, here's what you can do to improve stock GTT brakes for $1,000, it's quite a lot: http://www.sau.com.au/forums/topic/448613-r34-gtt-brake-improvement-without-breaking-the-bank/
Just in case anyone else is looking to do this, here's the cost breakdown including delivery (late 2014):
  • $662 - DBA T3 4000 Club Spec slotted rotors (Vic Performance Parts on eBay)
  • $164 - Remsa pads (GSL RallySport)
  • $178.45 - HEL braided lines (HEL on eBay)
  • $70 - Brake master cylinder stopper (Gumtree)
  • $17.96 - 2 x Nulon Xtreme Performance Super Dot 4 fluid (SuperCheap Auto)
Total $1,092.41 plus labour to fit braided lines and change fluid (I wanted to leave that to the experts). Not too bad for brake improvement on a budget.
Red stuff are probably fine, they're just not suited to your use case. Yellows are the next step up for EBC, but to me they seem about the same as the crossover QFM A1RMs, so still not a track pad. Last time i checked the yellows were AU$308, A1RMs were AU$180, so EBC are poor value.
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
