Disc Size R34 Gtt
Hi all,
I changed my front discs to 310 mm ebc grooved and red stuff
Planning to do the same at back
I want bigger discs for the looks of it but understand it won't fit it
Has anyone fitted a bigger disc than 310 or 296 for rear?
Do you gain much braking power by bigger disc as it has more surface ?
I also have braided lines and racing dot4 catsrol
What will be the next upgrade you do? Master cylinder or brembo calipers??
You don't want larger rear brakes without much larger fronts first.
Yep, another brembo on the front would be better, and but do you really need it or just for looks?
I did fit the front ebc dimpled and grooved and red stuff
It almost crashed the other day as it soften up while doing a hard braking so either needs bleeding or something is wrong
I am aiming to get 500-550 bhp from mine and want to have a brake which supports that power
I have seen posts people using asaptor kit to use evo disc of 350mm
My question is would 310 mm with brembo be as strong to hold the car at high speed ?
There must be a reason all super cars have a bigger disc
I have the AOR Brembo Kits front and rear on my R32 GT-R. The fronts made a massive difference but the rear upgrade was definitely required to restore the brake bias.
Just factor in your wheel size as factory 17" don't clear this setup.
If you were try try to put ~350mm rotors at the rear you would need stupendously big brakes at the front. Trying to match VERY big rears with 310mm fronts would be wrong wrong wrong wrong.
You will not need to upgrade your rears until your fronts are at least >340mm.
You want us to tell you whether to do that? Surely it depends on how important it is that you have large looking rear brakes.
If you have enough brake power for the driving you do then ANY brake modification you do from this point on is completely gratuitous and you have to justify spending the money to yourself.
Pretty sure track guys run stock rears with ~350mm fronts, so don't upgrade the rears until you're running something seriously big up front. If they're not pretty enough paint the callipers...With grippy tyres the rear gets unloaded more than with street tyres.
Failure modes are: pads overheat or fluid boils. Can you describe in more detail what you mean by "soften up".
EBC reds are a crossover pad, so almost certainly wont cut it at the track. What's the boiling point of the brake fluid? Dot 4 spec is only 230 degrees. Nulon xtreme will do 280, then Motuls to 320+. Did you do a full flush or just a bleed?
tl:dr pads are too conservative, if the fluid is anything less than 280 then swap it for nulon xtreme (since its cheap) and go from there.
If you are going to get Brembos for the front presumably they will be off a GTR so you would use the 324mm rotors as well. How did you manage to spend $1000 on GTT brakes? Was that for front and rear and some exotic pads or did you get expensive aftermarket rotors?
If you were using Castrol SRF racing brake fluid that is almost as good as Motul so probably not the problem (if you filled the system with fresh fluid and bled it adequately).
Seems likely poor pads were to blame.
If you want to splash out on bigger brakes still a set of D2 330mm rotors 8 pot calipers (sold under other names as well) with Pagid pads and 2 pot GTR brakes on the rear pulled up my big heavy Stagea lap after lap with no fade.
It's still not entirely clear to me what OP is after with his brakes.
If you're after performance not looks, here's what you can do to improve stock GTT brakes for $1,000, it's quite a lot: http://www.sau.com.au/forums/topic/448613-r34-gtt-brake-improvement-without-breaking-the-bank/
Just in case anyone else is looking to do this, here's the cost breakdown including delivery (late 2014):
  • $662 - DBA T3 4000 Club Spec slotted rotors (Vic Performance Parts on eBay)
  • $164 - Remsa pads (GSL RallySport)
  • $178.45 - HEL braided lines (HEL on eBay)
  • $70 - Brake master cylinder stopper (Gumtree)
  • $17.96 - 2 x Nulon Xtreme Performance Super Dot 4 fluid (SuperCheap Auto)
Total $1,092.41 plus labour to fit braided lines and change fluid (I wanted to leave that to the experts). Not too bad for brake improvement on a budget.
Red stuff are probably fine, they're just not suited to your use case. Yellows are the next step up for EBC, but to me they seem about the same as the crossover QFM A1RMs, so still not a track pad. Last time i checked the yellows were AU$308, A1RMs were AU$180, so EBC are poor value.
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
