I have a 25neo motor in my A31 with the Neo non hicas power steering pump. I have completely deleted the hicas and grub screwed the steering rack. Where there was a feed to the hicas pump, I installed a return line feeding back to the reservoir. I filled the reservoir with fluid, turned the wheels several times, topped up the fluid then started the engine. While the engine is running the rack completely locks up an I can't turn the wheel at all. Also the fluid is heating up rather quickly. When I shut it down I can turn the wheel normally.
Any ideas what the issue is??
https://www.sau.com.au/forums/topic/465276-power-steering-locked/
Then I must have removed something you did not.
After completely removing the hicas and the associated lines I was left with open threads in the steering rack and a hardline t-section going to nowhere.
Might be time to go back through the box full of stuff I removed.
What did you do with the second high pressure line from the pump?
Edited by RBceffy25
I think I just remembered that the R32 and Cefiro do differ in their power steer / HICAS plumbing. So maybe your HICAS lines do go via the rack. On the R32 the rear lines go from the rear outlet of the pump to the HICAS solenoids down low on the driver's side of the bay, then direct to rear of the car.
2nd high pressure line on car went in the scrap metal bin because the R32/RB20 PS pump was sold with the motor and the Neo's PS pump was used. Voila. Single stage pump.
Yeah figured it out. There are two distribution/damper blocks on the rack around the pinion, one for the hicas circuit and one for the main steering circuit. I had to swap a line from the hicas block into the main block. Sorted.
However, now it's shuddering like buggery through the wheel when I lock left but smooth when I lock right....???
probably just needs to bleed any residual air out of the rack. It will either sort itself after a few days, or you could jack up the front and turn lock to lock a few times until it starts running smoothly
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
