Power Steering Locked
I have a 25neo motor in my A31 with the Neo non hicas power steering pump. I have completely deleted the hicas and grub screwed the steering rack. Where there was a feed to the hicas pump, I installed a return line feeding back to the reservoir. I filled the reservoir with fluid, turned the wheels several times, topped up the fluid then started the engine. While the engine is running the rack completely locks up an I can't turn the wheel at all. Also the fluid is heating up rather quickly. When I shut it down I can turn the wheel normally.
Any ideas what the issue is??
Then I must have removed something you did not.
After completely removing the hicas and the associated lines I was left with open threads in the steering rack and a hardline t-section going to nowhere.
Might be time to go back through the box full of stuff I removed.
What did you do with the second high pressure line from the pump?
Edited by RBceffy25
I think I just remembered that the R32 and Cefiro do differ in their power steer / HICAS plumbing. So maybe your HICAS lines do go via the rack. On the R32 the rear lines go from the rear outlet of the pump to the HICAS solenoids down low on the driver's side of the bay, then direct to rear of the car.
2nd high pressure line on car went in the scrap metal bin because the R32/RB20 PS pump was sold with the motor and the Neo's PS pump was used. Voila. Single stage pump.
Yeah figured it out. There are two distribution/damper blocks on the rack around the pinion, one for the hicas circuit and one for the main steering circuit. I had to swap a line from the hicas block into the main block. Sorted.
However, now it's shuddering like buggery through the wheel when I lock left but smooth when I lock right....???
probably just needs to bleed any residual air out of the rack. It will either sort itself after a few days, or you could jack up the front and turn lock to lock a few times until it starts running smoothly
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
