I have a 25neo motor in my A31 with the Neo non hicas power steering pump. I have completely deleted the hicas and grub screwed the steering rack. Where there was a feed to the hicas pump, I installed a return line feeding back to the reservoir. I filled the reservoir with fluid, turned the wheels several times, topped up the fluid then started the engine. While the engine is running the rack completely locks up an I can't turn the wheel at all. Also the fluid is heating up rather quickly. When I shut it down I can turn the wheel normally.
Any ideas what the issue is??
https://www.sau.com.au/forums/topic/465276-power-steering-locked/
Then I must have removed something you did not.
After completely removing the hicas and the associated lines I was left with open threads in the steering rack and a hardline t-section going to nowhere.
Might be time to go back through the box full of stuff I removed.
What did you do with the second high pressure line from the pump?
Edited by RBceffy25
I think I just remembered that the R32 and Cefiro do differ in their power steer / HICAS plumbing. So maybe your HICAS lines do go via the rack. On the R32 the rear lines go from the rear outlet of the pump to the HICAS solenoids down low on the driver's side of the bay, then direct to rear of the car.
2nd high pressure line on car went in the scrap metal bin because the R32/RB20 PS pump was sold with the motor and the Neo's PS pump was used. Voila. Single stage pump.
Yeah figured it out. There are two distribution/damper blocks on the rack around the pinion, one for the hicas circuit and one for the main steering circuit. I had to swap a line from the hicas block into the main block. Sorted.
However, now it's shuddering like buggery through the wheel when I lock left but smooth when I lock right....???
probably just needs to bleed any residual air out of the rack. It will either sort itself after a few days, or you could jack up the front and turn lock to lock a few times until it starts running smoothly
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
