I've read a number of threads on here regarding this, but there's some info missing.
For safety, I'll be replacing the standard headstuds in my car with ARP studs as I'm planning on adding a bit more boost or going single (currently -9s, e85 and 335rwkw at 22psi). Gasket is stock and has not shown signs of issue.
I've been advised that doing one at a time should be fine and wont unsettle the gasket and I've been reading this regarding install.
http://arpinstructions.com/instructions/202-4207.pdf
1) Do I need to go and buy a thread chaser or is blowing out each hole with a compressor enough?
2) Any issue with me following the order as shown on that PDF? The first one being the middle?
3) Do any of the studs protrude into a water jacket and require sealant on an RB26?
4) There's mixed info regarding what torque to use given the standard head gasket has already been crushed and seated. Nissan spec torque or ARP torque?
5) This might seem like a stupid question, but in my last car the studs did not have separate nuts. That install guide says finger tight the studs into the block then finger tight the nut onto the stud then torque from there. Is torque applied to the assembled nut and stud via the nut or via the stud? Last car I did this on the torque was applied via the stud with a 10mm allen key fitting. Same here?
Cheers
You don't need to buy a thread chaser. Modify an original bolt you pull out to chase the threads by cutting a slot or two in it.
I would follow the regular tightening procedure.
They don't protrude into the water galleries.
You use the torque setting of the bolt manufacturer, so arp in this case.
The studs should only be finger tight, and preferably backed off so as to not bottom out. The nut applies the tension, the stud just goes in the hole and shouldn't turn when tightening the nut. If the stud was to be bottomed out hard it could / would deform the material around the base of the thread and cause issues with the bore.
Cutting slots in an old bolt is a nifty idea, cheers.
Regular tightenting procedure as in tighten to X, then tighten to Y then back off to 0 then tighten again? I thought that was to stretch the stock bolts.
If the nut is what I'm using, what socket size/fitting is it?
make sure you buy double hex socket set and 3/8" long sockets.. 1/2" won't fit and 1/4" you'll snap them.
(yes I learnt the hard way)... ARP studs comes with a sachet of assembly lube, more than enough for all the studs/nuts.
ARP kit arrived.
Still lots of conjecture about using Nissan's process of tighten, tighten, loosen, tighten again vs ARPs 3 equal steps to 105ft lbs.
Also, with the order, given I am removing one and replacing one stud at a time, should I be starting from the middle as per the diagram, or starting from the end, 14 in the digram, and working backwards. though in my head, given the gasket is already crushed and in place,m it shouldn't matter.
Nissan's process of loosening is so the threads are "burnished" together, removing high spots. No need with the higher quality arp and especially studs. There's way less contact are between the nut and the stud vs a bolt and the block.
Having had them ^ say that, I would be tempted to only do up each ARP stud to the same torque as the original ones are (supposed) to be tightened to, until they are all done. Then I would go around and finish them off.
For (artificially extreme) example....say the Nissan bolts are at 10Nm and the ARP bolts need to be at 200Nm. You wouldn't want all of them at 10Nm and only one or two scattered around wound up to 200! Unevenness is not desired.
I get you, get them even at stock torque spec, then increase to the ARP torque.
Stock being 103-113Nm, ARP being 142Nm ish.
Any issue causing damage by going tighter than stock? Risk to block/bore/threads/deform gasket?
Edited by ActionDan
RB not really
SR yes, the S15 I was working on, we stripped a thread, well the entire thread snapped off/out clean from the block as soon as we got to the ARP torque levels. Ended up using a timesert to fix the problem.. Not a fun thing to have happen.
    • There's a post from a member (can't recall who), went down the path of a twin scroll G30-660 and it's doing over 300kW+ AND comes on about the same as a high flow RB25DET turbo. Have your cake and eat it too in this case. TBH, if I had a 2nd chance of building my car again (i.e. someone gave me what I wanted for my shit box, but the deal was I had to re-build another R33 and keep the change) I would just pop in a stock NEO motor (with new seals, rod bearings, ARP studs, head gasket, sump, Nitto pump), get a smaller twin scroll turbo, modify the stock low mount (keep the divider in place), and make a solid 300kW on 98RON and call it a day.
    • It's all the sound deadening, and extra shit piled into them, plus all the extra (even though it's thinner) material for crumple zones. I can't fathom in modern cars why they need canbus to the headlights, and why the headlights must be vin coded on some cars to the ECU, BCM, and security module! Especially when they claim it's for security, yet, the canbus at the headlights let's thieves steal the car in minutes, so even more cars are being stolen! The Mercedes Sprinter 907 vans. They're a huge van, but a "basic" van. Yet they have that many canbus networks, plus two Lin networks, AND an Ethernet network. Logging a single network alone of 8 byte data frames, and they will generate a 20mb log file in 5 minutes. That's one network, and I can't remember the exact amount, but there's over 10 full CAN2.0B networks in them. I'm not a fan of modern cars, oddly, more and more I hate DBW, and all the bullshittery the cars try and interfere with. But all that bullshittery adds weight, plus crazy regulations on crumple zones, plus, ever picked a modern seat up, half of them have like 4 electric motors in them and will weigh 30+kg each. Then all the motors for things like adjustable steering columns blah blah blah. And did I mention the sound deadening so you can even hear an ambulance right behind you even if you 7.2surround sound is off?
    • Ah ok, yeah it should be flat, I believe the r34 battery tray has these 3 bumps in them they makes it line up and everything is flat, don't see how it would tilt if everything is secured.
    • Agreed it actively wants to kill you which I love driving fast cars slow is my stick
    • Awesome! I was thinking S14 since they are longer. I'll give those a shot. Thanks for the input!
