That's a ridiculous price. They aren't that hard to change. Id get a quote elsewhere if you can.
Did they quote you for OEMs? Or splitfires? Both types are overpriced either way.
How about these for only $400 delivered via express post - see here
Great quality coils for the price backed by a local 2 year warranty and I have them in stock, ready to ship immediately.
:cheers:
https://www.sau.com.au/forums/topic/465346-r34-coil-pack/#findComment-7745463
Not hard to change at all. Even as a first timer, should be able to do it in under an hour. Oem or splitfire is what most people on SAU generally recommend. I will agree with PW that $1500 is ridiculous. I would never go back to whoever quoted you that.
https://www.sau.com.au/forums/topic/465346-r34-coil-pack/#findComment-7745584
The most common plug-and-play options are:
  • OEM coil packs
  • Splitfires
  • Yellow Jackets
Ranging from $400 to $650, as per above. Beyond this there are LS coil conversion kits available but they start getting a bit fiddly with the Neo.
I have a set of used Yellow Jackets for sale here if that's something you would consider: http://www.sau.com.au/forums/topic/465355-fs-rb25det-neo-coil-packs-r34-steering-rack-an10-hoses-r34r33-transmission-parts-mel/
https://www.sau.com.au/forums/topic/465346-r34-coil-pack/#findComment-7745826
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
