Hi all,
So im continuing to do general maintenance on my 1997 R33 gtst. (changed MAF, cleaned AAC, service etc) nothing crazy.
I have noticed that there is a strange droning sound that occurs as soon as i rev past 3000rpm. it is sudden, makes the sound and then disappears as soon as i back off the accelerator and get it back under 3000rpm. Doesn't happen when cruising at 3000rpm, only when accelerating past it. i can't really explain the sound, it is low pitched droning, sounds like its coming from the drivers side in the engine bay.
Have researched this a lot online but when i check the videos of the things i have read it could be the sound doesn't match what i hear.
Any help you guys could provide would be awesome, dont like hearing my car sounding sick!
Thanks everyone
https://www.sau.com.au/forums/topic/465352-strange-droning-sound-from-engine/
Not an exhaust vibrating on the chassis or a rubber missing?
Thanks for the reply!
What sort of rubber do you mean? If i had to explain it better i would say the duration of the sound is similar to a BOV it is short and sudden and then disappears. I have been told that one of my engine mounts was worn, but from memory this sound started soon after installing new spark plugs, could either of those two things be responsible?
To anyone reading this, i have done some more research online and found that a lot of people have videos with a similar sound under 'misfire' and most are caused by spark plug related issues. Seeing as this started happening soon after i changed mine i think that might be the problem.
Can any recommend spark plugs for a lightly modified r33 gtst. I think i may be running the wrong ones. Thanks!
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
