barra33 Posted June 15, 2016 Share Posted June 15, 2016 I need to move my steering rack over slightly to drivers side more so i can clear an exhaust through. If i do it will i screw things up alot or just have to adjust the tie rods accordingly. Ive heard of people moving it forwards and backwards but havent seen anything about left to right. Cheers Link to comment https://www.sau.com.au/forums/topic/465354-steering-rack-moved/ Share on other sites More sharing options...
admS15 Posted June 15, 2016 Share Posted June 15, 2016 Im no expert but it doesn't sound like a good idea to me. Is there another option for the exhaust? Can you maybe space the rack instead to give you some more clearance? A picture would be helpful so we can see exactly what your dealing with. Link to comment https://www.sau.com.au/forums/topic/465354-steering-rack-moved/#findComment-7745868 Share on other sites More sharing options...
barra33 Posted June 16, 2016 Author Share Posted June 16, 2016 Ill get some pics when im done cutting out stuff from the engine bay and ready to start getting some mounts made up. Have found a guy doing the same build but with a turbo motor and says there is enough room so will talk to him Link to comment https://www.sau.com.au/forums/topic/465354-steering-rack-moved/#findComment-7746213 Share on other sites More sharing options...
dr phil Posted June 16, 2016 Share Posted June 16, 2016 Surely it would muck up because the pivot points in your steering arms will be offset to the drivers side, but your control arms pivots will be in the original location. Sounds like weird bump steering issues to me. Link to comment https://www.sau.com.au/forums/topic/465354-steering-rack-moved/#findComment-7746488 Share on other sites More sharing options...
