Hey guys,
Have some R34 bits left over
Dash $200
Gauges $100
Triple gauges $100
Glovebox $50
Orange indicators $50
Back seats $50
Stock wing $100
Seatbelts $100
Stock suspension arms $50
Hicas rack $50
ABS pump $50
Cradle lock spacers $50
AFM with pod filter $50
Boot gas struts $50
Window reg $50
AC Core $50
Ingition barrel $50
Door glass $50
NEO intake manifold with injectors etc $100
HKS biller fuel rail $50
Kinugawa Adjustable IWG $100
3" Blitz exhaust with 100cel cat $300
Full oil cooler/filter assembly with bracketry if wanted $500
TD06 10cm v band 3t housing $100
Make offers but i reckon everything is pretty fair. All located in adelaide but willing to post!
https://www.sau.com.au/forums/topic/465416-rb-r34-bits/
  • 4 months later...
    • Yeah the issue here is that we have a lot of topics, unless we matched on the exact word & phrase we'd get a million topics and the one you want will not likely be in the top 20 or so.
    • Yeah great idea, I have already added R32 Wiring Diagram but we can add as many as we want. 100% ! This has been something I've wanted to do for a while. I thought we could have a way for people to 'suggest' a link be added to the library when they come across something good.  We could kick this along by allowing members (maybe a subset) to tag threads they find to allow us to more easily find/locate/use good content, ie a tag 'for-library' which can then be added to the library and maybe have the tags reviewed and updated to better match the content. This would make it easier then to find the content when not using the library. We can also create pages that have lists of content with specific tags. That would allow us to add a tag and then have it automatically added to a page. We could have a page just for the 'for-library' content that we could then moderate and put wherever.  This excites me, the lack of structure with the amount of content is a little overwhelming.
    • Of course you can. That was a waste. Straight down one oil drain gallery and out the sump hole. Could at least have run the engine a little (obviously with at least minimum oil level on the stick).
    • Oh really? Maybe I'm being silly. I'll get some more shots. I had it higher but found that it went too high after a drive, I never knew this but exhausts can move around a bit when hot (makes sense, just never knew) and when it was higher it would make nice cooking plastic smells. That said, I could put some heat tape on a'la 90's R33 exhausts     Ha, I've spent a lot of my life in castle hill waiting for cars to be done. I think I'd prefer something closer but thanks D.
    • @Duncan Yes, changed filter every time. I don't have the service manual for the car yet (Car was imported and they removed everything when importing). I've been using the oil change threads in the forum as reference.   @Milkmun The second oil change was after ~4 months after the first months and I wasn't sure about reusing engine oil that was opened. The third oil change happened within 3 weeks of the second oil change and I used the previous leftover oil to just "clean up" the system. (Poured it through while the sump plug was open")
