Hey all,
R32 GTR i bought has 340mmx32mm two piece rotors with F40 brembo calipers on it. The rotors need replacing but im strugling to find a replacement that will fit the caliper and my 17in enkei rims. 340 is right on the limit so cant go any bigger..
Any help much appreciated
Sam
https://www.sau.com.au/forums/topic/465427-rotors-to-suit-f40-calipers/
Well good luck. I tried Project Mu, DBA and any number of others. Maybe Harrop at a pinch?
Either that or use 324 x 30's off a 33. Problem being you will need new adapters.
Are they AP or another brand. AP wanted drug money from what I can remember.
Edited by djr81
  • 1 month later...
I was in the same situation where my GTR came with F50 kits and the rotors needed replacing. I tried to source new rotors locally and overseas but no luck (I saw some full kit online from overseas, but not any replacement rotors) Not to mention the long term cost when I had to replace them again in the future. I ended up getting a custom made hat and the DBA 5k T3 rotor to fit.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
