Hi guys....
The steering wheel doesnt seem straight when im driving straight ahead on a dead flat, straight road.
I recently had new tyres fitted thinking that that couldve been the problem. Had balance and alignment. Problem is still there on some roads. Falken specialist said it's cos the car is lowered and it tracks the camber of the road.
Fair enough but why is it when after ive been driving for a few minutes and i build up speed on a main road that i can almost see the steering wheel turning in my hands (always the same direction - down to the left) but the car still steers a steady straight course?
It's so disconcerting as you're building speed to have to readjust your driving style every few mins to compensate for the changes in steering wheel movement.
I was reading in HPI that there's a thing on GTRs called a steering wheel position sensor which can be zeroed.... could this be the prob on my GTSt?
What where the wheel alignment specs when you had it checked?
I will bet it has less caster on the left hand front than the right, common problem. Either that or they didn't check the rear wheel alignment. Either way the specs will tell the story.
Dunno about the specs but i made sure they did a rear wheel alignment aswell..... so more than likely castor...
Im getting a servie tomorrow so ill make sure it gets checked
Tell me something though, it's highly unlikely that the camber of the road would cause such major steering wheel alignment issues eh???
Just like a dyno is for an engine, I never leave the workshop without a printout of the wheel alignment. If you have a lack of caster on the left, then the road camber just makes it worse, it's like 1 + 1 = 3. If there is a left front camber problem as well (even a slight one) then 1 + 1 + 1 = 5. And some roads have way more camber than others...........
Hope that helps :)
HSVKLR - is what u are experiencing like this - say u start off driving slowly, steering wheel is straight. then as u build up ur speed, you find that you have to turn the steering wheel to one side, but the car is still going straight?
two things -
1) HICAS may be leaking on R32 (happened once to me, locked it and problem went away)
2) problem came back later on, more severe. turned out that one of the steering rack rubber bushes thingy was worn out and allowing unwanted movement - not sure what they're called, it was this rubber ring like thing that are on both sides of the steering rack. ordered replacements from Nissan, got it the next day and problem gone.
hope that may help
KJ
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
