Hi guys,
Up for sale is my RARE 17 x 9 Panasport G7 3 PIECE rims with tires in good condition, no buckle, no cracks and not bent. Rims have some small scuffs around the lips but does not affect the appearances or what its use. (Refer to pics)
Wheels specs:
SIZE 17 x 9 +18 offsets all round.
REARS have more dish then front as fronts have a different disk type to clear big brake setups.
Stud pattern: 5 x 114.3
Tires:
Fronts: 215/45/17 Continental Max BRAND NEW
Rears: 225/45/17 Achilles ATR 85% left
Wheels are a perfect fit for my S15 Silvia and are good size for many other vehicles.
Price: 1350 nego
Inspection and test fits is welcomed. Im located in Vic Melb. Interstate buyers are welcomed. Any other questions, details or book for an inspection please contact me by pm, txt or call me on 041210834four
Thanks for viewing,
Bob
is there any offset change between them because of the lips or are they still +18 all round like you said haha thats confusing af
It has a thicker hub, pushing the spokes out further and only requiring a shallow outer lip to maintain the same offset as the shallower hub with wider lips.
I'll hide these comments tomorrow once you've read it Alex.
    • That may not be so tricky with a changeover relay (again, with LED indicator only to reduce load on existing headlight + source)  30 to indicator + globe side 86 and 87 to headlight parker + 87a to original indicator + chassis side 85 to chassis/earth repeat on each corner, sorted, no diode required
    • There might have been some "hard core" decalcification going on in the cells to create that noise As for chargers, I stick all our cars on a trickle charger every few months to "clean out their pipes/cells", the Mrs battery in her Mistsu ASX is still running its OEM from new battery 10 years on, and that thing does alot of short drives, and it can sit around for ages without a good long run
    • I'm not sure the diode only will give the desired result. I'd probably approach it with a couple of relays (And you still might need a diode too!). You need to be able to break the constant feed from the headlight to the orange corner globe when the indicator is flashing. Not knowing which Skyline we're talking about specifically here too (And it may not matter, but I don't know the R34 column switches) you'd likely need to rewire the stalk, so that the indicator power itself no longer runs through the stalk too, as now you need it able to trigger a relay that will break the constant supply from the headlights to the indicator, then you'll need a separate relay to trigger the indicators to come on (Replacing the internal action of the indicator stalk).
    • Weird story from me My Toyota 86 was with Commbank comprehensive but for market value (who they use to underwrite is unknown) When I munted it beyond financially viable repair in 2020, rear end smashed in to the point it bent the rear quarter and roof, they knew I paid $31k cash for it because I told them, they still paid me out $38k, as all the 2017 limited edition variants with typical Km and condition were going for between $36-41k, so they did weird math and came up with $38k I never officially mentioned any of the mods that I had done, but as they were not the cause of the crash they were not fussed at all, the insurance inspector actually asked if I wanted to replace all the mods with the OEM stuff if I still had it laying around before they took the car I still came out of it behind though, because I had probably dropped $20k in it with the suspension (bent after the prang), wheels (bent as well) and "other" mods, that the inspector asked about But still, as the market value was higher than what I initially paid, and they paid out market value To say I was surprised with the outcome would be an understatement  Weird, but true, but probably just lucky with the inspector on the day I guess  Sadly, I don't think if I munted the old NC1 MX5 I would get the same result Meh, pay to play
    • Well, the car is back, all straight and shiny, for how long for is anyone's guess  After picking it up we went for a bit of a drive, Jebus I really enjoy driving this little thing, hopefully the weather let's us go for a nice long cruise this weekend as it will be out of my hands for at least a few days next week when it heads back into Mania on Monday It's weird, whilst I do always enjoy going for a drive, the NC makes me feel like a kid who has just got his first car, and they just want to drive wherever and whenever they can I really need to look into the MX5 Club of NSW
