xanavinismo Posted June 24, 2016 Share Posted June 24, 2016 Hi all, Im currently removing the transfer case on my R34 GT-R and I can pull it out about 1 inch, but then I cant seem to seperate it any further from the gearbox as I cant get it past the selector?? Ive uploaded pics for your reference...Thanks for you help guys! Cheers, Glen Link to comment https://www.sau.com.au/forums/topic/465481-removing-r34-gtr-transfer-case/ Share on other sites More sharing options...
iruvyouskyrine Posted June 24, 2016 Share Posted June 24, 2016 Never played with GTR stuff before but it looks like you have to take the selector thingy off? It should just be a roll pin holding it in. 1 Link to comment https://www.sau.com.au/forums/topic/465481-removing-r34-gtr-transfer-case/#findComment-7750532 Share on other sites More sharing options...
Shoota_77 Posted June 24, 2016 Share Posted June 24, 2016 Selector has to come off. There is a double roll pin (smaller roll pin inside a bigger pin!) Knock the small one out first, then the bigger one. Don't try and take both out at once.You need to slide off the selector AS you're removing the transfer case. They need to be separated a bit first to allow room for it to slide off the selector shaft. 1 Link to comment https://www.sau.com.au/forums/topic/465481-removing-r34-gtr-transfer-case/#findComment-7750556 Share on other sites More sharing options...
xanavinismo Posted June 24, 2016 Author Share Posted June 24, 2016 Yep thanks guys that worked perfectly =D Cheers, Glen Link to comment https://www.sau.com.au/forums/topic/465481-removing-r34-gtr-transfer-case/#findComment-7750598 Share on other sites More sharing options...
Duncan Posted June 24, 2016 Share Posted June 24, 2016 oh, and dont drop the roll pins into the box.... Link to comment https://www.sau.com.au/forums/topic/465481-removing-r34-gtr-transfer-case/#findComment-7750675 Share on other sites More sharing options...
xanavinismo Posted June 24, 2016 Author Share Posted June 24, 2016 I dropped the small one haha! But im pulling transfer case apart so ill find it again : ) Link to comment https://www.sau.com.au/forums/topic/465481-removing-r34-gtr-transfer-case/#findComment-7750717 Share on other sites More sharing options...
Duncan Posted June 24, 2016 Share Posted June 24, 2016 hopefully lol Link to comment https://www.sau.com.au/forums/topic/465481-removing-r34-gtr-transfer-case/#findComment-7750722 Share on other sites More sharing options...
