hey guys, want your opinion on this
I'm looking at the Aftermarket Industry's SP800 integrated surge tank
isn't having 3 (warm) pumps inside a 3L surge tank going to heat the fuel in the surge tank?
wouldn't having the pumps external be more efficient in terms of heating the fuel?
After having numerous fueling issues associated with high temperature fuel on highway driving (45 min +) I decided to cut voltage going to the pump on cruise and it helped immensely.
My setup is a DW300 in tank (lift pump) feeding a small Integrated Engineering sump with a single AEM 380 lph pump going to the Hypertune fuel rail setup (V2 complete intake) and an aeromotive regulator. The lift pump flows into the sump and returns back to the tank (keeping it full) and runs on battery voltage on a relay (switched on with computer fuel pump out). The AEM380 lph is wired such that I am running battery voltage to/from the pump back into a 5 pin 30 amp relay. On the NC leg of the relay I'm going to the factory voltage controller and letting that reduce voltage by limiting the grounding of this leg of the pump. The switched leg (NO) goes straight to ground and is controlled by my Haltech at 3k rpms and 0 psi boost. This way when I'm cruising and the pump is at low voltage and is quiet...Then pretty much anytime I am in boost I am getting full battery voltage through the pump. It helped ALOT. This pump would be extremely noisy after the fuel was overheated and would sound like fuel cavitation after 45 or so minutes especially at 1/3 or less fuel.
IMO if you have multiple pumps, you should be running some sort of fuel pump control in order to reduce added heat. It's also silly IMO to just blast your FPR all day long with more flow than it should be seeing.
In the next week or so I will be dumping the factory voltage controller and going to complete PWM fuel pump control for both pumps on Solid State Relays. This way I can get nice smooth fuel controls for both pumps and can forget the factory setup altogether.
  • 5 months later...
Anyone else installed one of these integrated surge tanks?
I've had a bit of work done at East Coast Customs and the only think holding me back now is my fuel supply.
New fuel rail, turbosmart reg and Bosch 1000cc'ers have been purchased. But the team were chatting to me about fuel supply from the tank.
From what I've researched there are three schools of thought (keep in mind I'm staying on 98):
1-External tank and pumps (I'm not interest in stuffing around with this)
2- Surge tank mounted in boot with 2 pumps (most likely 044's)
3- Install integrated surge tank with pumps in it on the rear shelf in the r33 boot
I like the idea of option 3, it is neat and tidy and can hide behind the fabric partition in the rear boot near the battery tray. Option 2 is probably the most common, but I don't like the idea of the pumps and tank being so exposed if the boot is opened. My car is essentially a sleeper with practically no external modifications to avoid unwanted police attention (and clean skylines are rare these days).
500-550hp goal. Currently maxed out at 430rwhp before the tuner claimed my injectors were maxing out.
Are in-tank pumps really a viable alternative to surge tanks, do they perform well these days under g-loads?
I know I've been out of the game for a good 3-4 years now, but if they are, well damn-i'll buy one tomorrow.
Quick note- this is not a dedicated track car, not a daily, just a toy that sits in the garage for the odd track & skid day.
Whoever is telling you you need twin walbros or 040's for 98 is probably being a bit silly here, or thinking you'll end up going E85 down the track.
Single walbro 460 mounted PROPERLY in the tank will do the job fine. Unless you want to do a trackday with only 15L of fuel left in there.
Otherwise you're buying not just a surge tank, but lines and fittings front to back that you don't need.
    • Agreed it actively wants to kill you which I love driving fast cars slow is my stick
    • Awesome! I was thinking S14 since they are longer. I'll give those a shot. Thanks for the input!
    • Far out, that thing looks like some loose fun!  Nothing beats the rawness of a filthy old Nissan with zero aids to keep the wheels pointing in the right direction like modern "fast" cars!
    • If there is no ridge at the inner edge of the battery tray (ie the battery tray is flat until it rolls off the edge into the open space of the bay), then no, it won't matter if it overhangs. If the battery would be propped up by any ridge, then that wouldn't be ideal. The bottom of the battery case would not be sharing the load. It would be concentrated on one end edge and a line across the bottom where it contacts the ridge. And possibly it wouldn't fit under the locking clamp either. I only upsized my battery to the max because: I sometime have to leave my car undriven for weeks at a time while I am away for work. On the previous battery (replaced a couple of months ago) I had to leave it undriven for months at a time!! I sometimes abuse the battery by running the stereo up loud for many hours while I wash and polish it. This is how I realised that the previous battery was on its last legs, because it got to the point where it was too weak to start after a couple of such. It was 7 years old though, so, fair play. Supercheap had a good special so the X was only ~$250 instead of ~$320, which seemed sufficiently less painful. I had already been using NS70 for the previous 2 batteries for most of the same reasons as above. The X is just the final boss level. I was contemplating going LiFePO4. But it's like $900 to do that properly, and while you save >10 kg of weight, you can likely only expect a couple of years longer life. So meh. Maybe when the price comes down further. Although, in ~7 years when I have to replace this one, I might not be allowed to drive such an anti-social vehicle anyway.
    • If I get a larger battery and it hangs off the edge of the frame rail, would this be an issue? With FMIC a lot of people downgrade their battery size due to less room for shit, was wondering if it would affect anything but it would still be tight via the clamp.
