To answer Yangs question, idle is mildly rough, but definitely noticable and varies.
It started straight after fitting new plugs.
So either I have a faulty spark plug, or the 7's make a difference on idle from the factory spec 6's that were in it, or one coil pack has deteorated / been damaged.
The old plugs looked really old, so may have damaged coils.
They look original so are probably 15 years old.
I've read coil packs do lose their effectiveness over time.
I have had all the symptoms below :
Hard starting - hot
Inconsistent fuel consumption- did a run down to the snow- got 380km with a full tank, loaded a bit
Rough idle- pre new plugs, idle was so smooth, I was frequently checking the gauges to see if the engine was running.
Stalling, a while ago.
Car seems louder and engine sounds different- cruising.
On hard accelleration it all seems fine, just idle and cruise.
It is an expensive trial and error but with all the above..
thanks for all the advice.
having said all that the car just made 237 kw
Edited by conan7772
https://www.sau.com.au/forums/topic/465487-m35-coil-packs-continued/
for the hard starting when hot, i think someone already told you about the bigger injectors? so maybe you can try jump another battery together with your stock one then start engine again when hot.
for roughly idle, the idle is good with old plugs? beside coils, did you try another AFM
also after stall, can you restart the engine? or consistently stalling after first stall? any black smoke when roughly idle?
anyway, i have spare stock coils/AFM/throttle body if you want to do cross-check.
btw, did you sort the ignition cel problem?
Edited by YangLIU
hot starting is much much better now, Jez did some magic there.
didn't try another afm, don't think mine has any faults
after stall, could start engine straight away, idle was very low back then, now with e-manage much better
no black smoke
ignition cel still not fixed- chip didn't work, or maybe ecu picking up bad coil pack ?
I'm gonna get new ones anyway, getting old ones is like buying old spark plugs
I use this website for part number, works great and i have been into the local Nissan dealer with a printout and they were able to source exactly what i needed
http://jp-carparts.com/nissan/figlist.php?maker=nissan&type=153&cartype=8
as for the part your after see attached
