Thought I'll throw up a quick build thread of my r34 sedan drift car been building over the last few months
I picked the rolling shell up for $1000 it had 28132kms genuine kilometres on it its a GT rb20de factory manual
Since I've purchased it I've put why I've worked out 22k into the car hasn't got me far but it's a start haha
Engine:
Rebuilt
rb25detneo
S2 port and polished head
Camtech 272 camshaft a vvt deleted
Upgraded valve springs
Greddy style plenum 80mm throttle body want to change it out to a Q45 TB though
Custom high mount exhaust manifold the turbo site more forward compared to 6boost
T78-33D trust performance turbo
50mm 4 bolt gate
1000cc injectors
2xbosch 044 fuel pumps feeding
-08 speedflow 100series hose
Proflow fuel reg
Super spark coilpacks
Exedy twin plate clutch
Standard rb25det push type gearbox
KAAZ 2way diff
R33 rear subframe
Solid PBM sub frame bushes
Tein coilovers
Hydro hand brake directly fed to the rear brakes
(Abs has been removed)
Oil cooler and filter relocation kit with gates hoses
20L speed masters baffled fuel cell with sump
Coming in the mail is a uras body kit and my AGI 6 point cage which should all arrive next week
Pics aren't in any specific order
post-143301-1466825749651_thumb.jpgpost-143301-14668257642446_thumb.jpgpost-143301-14668257753949_thumb.jpgpost-143301-14668257938995_thumb.jpgpost-143301-14668258039832_thumb.jpgpost-143301-14668258150219_thumb.jpgpost-143301-14668258389274_thumb.jpg
Edited by Dorimon34
https://www.sau.com.au/forums/topic/465488-og-flagship/
    • Did a conversion on my rb20 with rb25 cam and pulley, controlled it with a solenoid (forgot the port diameter of the solenoid)  and made an oil port on the cam cap to lower pressure in the journal. Difference  is day and night, the rb20 isn't dogshit down low anymore, not a powerhouse but this had add much welcomed torque down low. Boost build a bit sooner and torque rise way more when it start building boost. Only need to deactivate the VTC past 6500/7000rpm.   Knowing how it help with only 2L, having it on 2.6L it should be a mod to think about early on as it gives a lot of performance on most on the rev range.
    • https://www.nengun.com/hks/valcon-rb26-v-cam-system   no controller but most will use ECU to control anyhow
    • Not too sure, the throttle body has 4separate plugs going to it. Im not sure if the throttle is driven by cable and the motor is for traction, cruise and something there light blue one is TPS. i don't understand why the throttle won't open with the cable until about 3/4 on them only moves the valves very slightly
    • There are other crowds doing 25Neo conversion kits.
