Thought I'll throw up a quick build thread of my r34 sedan drift car been building over the last few months
I picked the rolling shell up for $1000 it had 28132kms genuine kilometres on it its a GT rb20de factory manual
Since I've purchased it I've put why I've worked out 22k into the car hasn't got me far but it's a start haha
Engine:
Rebuilt
rb25detneo
S2 port and polished head
Camtech 272 camshaft a vvt deleted
Upgraded valve springs
Greddy style plenum 80mm throttle body want to change it out to a Q45 TB though
Custom high mount exhaust manifold the turbo site more forward compared to 6boost
T78-33D trust performance turbo
50mm 4 bolt gate
1000cc injectors
2xbosch 044 fuel pumps feeding
-08 speedflow 100series hose
Proflow fuel reg
Super spark coilpacks
Exedy twin plate clutch
Standard rb25det push type gearbox
KAAZ 2way diff
R33 rear subframe
Solid PBM sub frame bushes
Tein coilovers
Hydro hand brake directly fed to the rear brakes
(Abs has been removed)
Oil cooler and filter relocation kit with gates hoses
20L speed masters baffled fuel cell with sump
Coming in the mail is a uras body kit and my AGI 6 point cage which should all arrive next week
Also in the pics is the ex JWS 34 drift car I bought it as a roller and stripped it out as I need a few essential parts from it its currently re-homed with a fellow drifter getting rebuilt to its former glory
post-143301-14668280840093_thumb.jpgpost-143301-14668281056211_thumb.jpgpost-143301-14668281163667_thumb.jpgpost-143301-14668281255371_thumb.jpgpost-143301-14668281373727_thumb.jpgpost-143301-14668281459823_thumb.jpgpost-143301-14668281551266_thumb.jpgpost-143301-14668281740921_thumb.jpgpost-143301-14668281896736_thumb.jpgpost-143301-14668281988842_thumb.jpgpost-143301-14668282139949_thumb.jpgpost-143301-14668282288454_thumb.jpgpost-143301-14668282380346_thumb.jpgpost-143301-14668282443015_thumb.jpgpost-143301-14668282809332_thumb.jpg
  • Like 1
https://www.sau.com.au/forums/topic/465489-og-r34-driftcar/
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
