Hey guys I started pulling everything to do my water pump today and have gotten to pulling the timing belt. I have the cam marks lined up for the intake and crank however my exhaust cam is advanced by 1 tooth. I have searched a lot and read you can gain mid range by doing this. What is troubling me is if I retard the exhaust cam and make it so all the marks line up correctly is this going to throw off my tune? Will this make any other differences that I should be aware of? Mod list in signature any information appreciated.
https://www.sau.com.au/forums/topic/465502-exhaust-cam-timing-question/
Got the water pump and timing belt replaced, ended up just keeping timing marks aligned in stock orientation as fsm says. Weird thing happened though.
After finishing job I started the car to burp the cooling system, all was well started fine and idles smooth, however once it got to operating temp it's like a switch flipped...idle was super rough and when given throttle would miss and sputter. I made sure all alignment marks were correct when I buttoned it up and the car ran perfectly for around 15 minutes. I can't figure out what the issue is. I let the car cool down and even on a cold start its running rough. Any suggestions?
Edited by Ed.williams5
So an update:
Car idles but sounds like it has a miss. I went ahead and replaced the coolant temp sensor thinking that may be the issue however even with the replacement it's still running like crap.
I made sure that car is timed correctly at 15* btdc with tps unplugged, I did notice however when adjusting timing nothing really clears the stumble up whether I advance or retard the timing. I may see if I can find a known working cas to see if that solves the issue.
Either way I know it has to be something electrical because it literally started running like crap at the flick of a switch.
I'll look into that next kiwi. I am running ls coils at the moment however I was thinking and wonder if I hook up to my Ecu if it maybe can point me toward the issue too (running haltech platinum pro)
Update:
Don't know why I didn't do it sooner lol. Hooked up my laptop and pulled codes and a datalog. Had 3 codes 2 tps codes from when I was adjusting timing and 1 engine overheat code. Car was running in limp mode with as safety from ECU. Cleared all codes and car runs perfect once again. Was also able to verify my timing through the haltech which is right at 18* base so may go back and adjust it down ever so slightly to 15*. Thanks for all the suggestions and help everyone!
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
