Its long overdue, I've put it off for long enough, but very soon we will be undergoing a massive update of the site to Invision 4.
Invision is who we use for the forums and main components of SAU. Some addons are 3rd party (timeslips, spy, trader ratings, etc).
The version of Invision we're using is no longer supported at all and the few bugs I've raised with them lately have not been fixed.
I've been testing the process of upgrading on an external development server and it is very solid but also seriously time consuming with the latest test update of BASE forums functionality taking several hours.
The soft date for initiating the update is this Friday at around 7pm.
Things you need to know;
  • Things will be a little different when you first log on after the update.
  • The update is worth it with many very positive features being added.
  • We'll be starting with a single theme initially but will be settling on a second (dark) theme in the weeks following the update.
  • There will be hiccups! We request that you stay patient and log your bugs and problems in this thread.
  • Supporter options (subscriptions) will be disabled from mid week (Wednesday) and will likely be the last feature to be updated (as we will be migrating subscriptions to a new system to work with Invision 4.)
Ask questions in here.
Thanks.
  • Like 7
I might be missing something but with the view unread content feature, it is showing each reply to a thread not just the thread title itself... eg: the whoretown thread is filling up results with each reply not just the one result.
Any idea's how to customize so it is like the old "view new/unread content" so it only shows one result per thread and more then the past hour?
The big issue ongoing atm is that search isn't indexed which means that things that use search (new/unread) might be operating at 50% until the indexing is finished.
  • Like 1
@PranK hey man.. good job on the update however the top AdSense banner isn't responsive so on mobile when you hit the hamburger menu it doesn't come up.. instead you need to scroll all the way to the right.
Google offers full responsive banners now, so you don't need 2x sets of banners like in the past and switch between them at certain breakpoints.
  • Like 1
Yep, I'm awaiting new ad tags from our agency, hopefully this will be sorted today. :thumbsup: Thanks for letting me know!
I can't seem to load this page on Edge at all.
Just attempts to load SAU.com.au/forums over and over then gives up saying the page can't be loaded or "there is a problem with this webpage"
Works fine in IE, Chrome, FF.
Dunno if reported yet but hey now it is!
Thanks for letting me know, I'll find a windows machine and do some testing.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
