Ok so I just had another notification pop up. It was for the "hello from Canada" thread in the newbie introductions area. The thread is 2 days old and only had 1 reply, also from 2 days ago
On 01/09/2016 at 1:44 PM, mad082 said:
I occasionally get random notifications from the mobile app for threads that I've never participated in, in sections of the forum I rarely go into. Any idea how I stop them. The notification just has a speech bubble with 3 dots in it.
I too have been having this problem, probably get around 4-8 notifications per week. random threads that i have nothing to do with.
On 9/13/2016 at 7:41 PM, SimonR32 said:
@PranK ?
If you go to 'Activity' in the menu, you should be able to choose your content from the available streams - can you check that?
  • Like 1
And these rogue notifications are only the browser ones right? All other notifications are accurate?
Ok got a new one, when I create a new thread and click the "insert other media"  and insert image URL it posts an image from external link in the thread.
When I try to do it in a reply you type the url in and click "insert into post" and it does not accept it.
I don't know what has been happening over the past week but the app has stopped working for like 5 days straight. Even had to uninstall which did nothing.
Issues are,
Open app
Asks me to login
I do
Says "can't contact server"
Then the times it doesn't ask me to sign in it won't load any news feeds.
Galaxy s7
11 minutes ago, Hadouken said:
Okie dokie. Today the app is perfect. I don't know what happened....
Oh great, the new one might break it! :D
  • Like 1
@PranK Hi I'm still having issues with the participated icon tab on SAU android app thats been updated today, doesn't show any participation. It says "no topics" .
I try to use the URL website that seems to work.
Cheers Mark.
Is there any way to change the sort order of the threads in the Subscribed tab in the Android mobile app?
The old version (pre site upgrade) used to sort based on latest posting whereas the new app (including yesterday's upgrade) seems to sort based on date subscribed.
Cheers
    • Structured text and other high level PLC programing languages are not allowable in Functional Safety. They are very difficult to audit. My PLC stuff is almost exclusively oriented towards Burner Management Systems which are a particularly pernicious form of Safety Instrumented System, when implemented in an SPLC. Even the part of the code written to work in the non-safety logic part of the PLC, like with a Siemens S7-1500 series, still needs to be treated as if it was safety code, with access restrictions, code fingreprints and the like. And Allen Bradley can go EABODs. They ae full of shit. They have this whole lie going on where they say if you use a ControlLogix controller and its IO, and then just duplicate the IOs (ie, run in series or parallel depending on type, to try to make it "fail safe") and "use these programming styles and place these restrictions on what you do" that you can achieve SIL2. What a load of crap. They just get away with it because no-one in the US seems to understand the first thing about Functional Safety and carries on as if all they have to do is buy only SIL2 rated equipment and hey presto, it's a SIL2 system. Idiots. /rant
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
    • It doesn't seem to follow revs. Oddly it seems to follow TPS a little bit from what I can see, but with some delay a bit. IE end of the graph, when he lets off throttle fully, pressure drops a lot, then slowly builds back up, but rpm is on a nice cruisey drop off. I do agree though, it seems very electrically.
    • I just try to entirely stay away from ladder now unless it's something basic maintained by electricians. Even then and to your point, it mostly ends up being blocks I wrote in structured text.  PLC's are slowly going towards C, C++ and C#. I just wish Allen-Bradley would jump on the bandwagon.
