I don't get it? The browse function has the exact same layout as the previous version.
Now it has headers for participated and timeline which is great!
The font could be smaller to accommodate more post per scroll though.
Site doesn't remember my login details even after I tick the remember me box.
Upon entering my username and password and clicking login, the site tells me it is a incorrect password. Without changing my details I hit login again and it logs me in.
Clicking on the last post in a thread doesn't take me to the last post always to the second post in a thread.
Currently using chrome but find the same issues under IE.
Regarding the login issue, can you clear all cookies for SAU and try again?
I searched for the option to delete attachments in my threads. i.e. pictures, as per previous version and failed :(
Does this version retain that functionality? Looking to reduce the storage used by deleting my old pictures.
I've just put up a post with four images but it keeps duplicating them.  I've deleted them and started again a couple of times, trying different things, but I keep getting dupes.
1 hour ago, jmknights93 said:
Dark theme lots of issues with incorrectly styling. Anyone else spot this?
Can you share some screens? I tested it for days with the admins and it was fine.
15 minutes ago, *LOACH* said:
In regards to likes being anonymous. It is that way for all of them for me. It always says someone or the number of likes but I can never see who.
Aha! Its a setting "can view who gave reputation" - i didn't know it existed. I have enabled that for members and i'll work through other groups also.
  • Like 2
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
