42 minutes ago, PranK said:
Aha! Its a setting "can view who gave reputation" - i didn't know it existed. I have enabled that for members and i'll work through other groups also.
Awesome! I can see them all now. Thanks Christian. I realise you must have a whole tonne of stuff to go through and this would be a minor issue in the scheme of things so I am especially grateful you fixed it... and immediately after I bought it up. You sir, are a legend :)
  • Like 1
Aw shucks! :) You're welcome!
  • Like 1
Having some problems logging in with iphone - keeps asking me to log in again but doesnt recognise me as a user.
I first registered with FB connect - i tried logging in with Facebook name as well as Username - both dont work
iphone 6S+
iphone 6S+
OK, make sure you use the correct login name - the display name no longer exists.
Is it the latest version of the app?
Hey mate, yes latest version of the app - logging in with my FB name - doesnt work as well.. if im on the computer - no problem logging in - just on the phone.
Will say - Looks like you don't have an account
9 minutes ago, Hank Scorpio said:
Dunno whether this has been covered yet but for some reason the date format is mm/dd/yyyy not dd/mm/yyyy
Where are you seeing that?
3 minutes ago, Hadouken said:
My "participated" section is not working.
App on android
Yep, this is based on search which is being rebuilt, might take another few days.
  • Like 1
Mainly in quotes, i.e in my sig it says - " On 3/26/2014 at 8:52 AM, Anfanee said: "
Aha! Ok cool, I'll find that and fix. Thanks!
  • Like 1
On 7/22/2016 at 9:23 PM, lanky71 said:
on the "unread content" page, the adchoices triangle appears halfway down the page and moves with you as you scroll.
See picture:
Will investigate.
On 7/23/2016 at 10:58 PM, Robzilla32 said:
Previously subscribed threads seem to be automatically unsubscribed.
E.g. "Spotted Thread"
Is this still happening?
On 7/23/2016 at 11:22 PM, z00key said:
Yes my main thread I participate in (wa wasteland) am having to re-sub almost daily
As above
On 7/27/2016 at 0:41 AM, jonny8ball said:
Search function doesn't work on iPhone app. Have tried searching for everything and anything and the search function brings up 0 every time emoji20.png
Try again now.
On 8/1/2016 at 0:34 PM, GTofuS-T said:
Unable to send PM's as a copy to multiple users
Is this a functional limitation or a bug?
4 hours ago, Trex said:
when someone has been quoted we used to be able to press a 'view quote' button that would take us to that post.
Any chance we could recover this feature?
Hit the little black arrow at the very right of the quote title.
    • I mean, I can confirm the TPS is at 100%.... I can confirm when we installed the TB and setup the cable that the TB was indeed fully open at max pedal travel.. the same 'curve' (WRT MAP vs MAP) existed with the previous setup/TB/manifold as well... No, we did not do a run with no intake connected. I would love to go back in time to do such a run to rule out the intake. It would have also been good to do a run with the airbox lid off. There's a test there where increased IAT vs more available air could be a positive tradeoff. I remember taking the lid off my R34 Turbo setup back in the day and noticing a monster increase, even if IAT's did go up. Could be similar. Hard to test unless I find a very deserted road.
    • That's actually encouraging to be honest. my motor was rebuild many years ago but it's probably done less than 30,000kms and fucc all limiter or drift, majority street / drag / roll racing. It'll be fine 馃挭馃徏 I don't even have lines or a can for the cam breathers installed yet, there is zero oil residue or splatter on or around them, it drives beautifully so it seems healthy. Just a ticky lifter, yet they're almost brand new oem genuine Nissan and haven't done many kms at all...
    • Have you confirmed the throttle body goes to WOT (and stays there) during the run?
    • I'm having a problem. I think it was mentioned above somewhere but can't see it.  I'm stuck in the cycle of, sand, filler, low spot again, put filler, sand, low spot again, now i put filler again and a thicker portion which seems to have helped but I got low spots in other areas. In the image. Circled in red thats where the original low spot was and the shape is the same as the red out line. I've more or less fixed that (still low spot up the top but now I have low spots where the green circled part is.  Is likely the issue that I didn't start with a course sand paper? I sanded the filler with 240 to reduce the risk of not going to far but maybe the issue is that I'm only taking off enough material to remove some of the filler but not the high spots. I now started sanding with 120 and I think I'm seeing a difference. I did fix one dent the other 2 are f**ked and seems like I made another low spot which is indicated by the furthest green circle on the left handside. Any thoughts and solutions?   Also second image. All of these rock chips, can they be filled in with primer or do i need to fill them all with filler/putty? So many rock chips on mine lol.
    • Well, I had an Edward Lee's special edition odo windback car/motor with a RB25DET S2 and I put down 372kW with a good amount of track abuse for 1.5 years before the ring lands decided it didn't want to stick around anymore 馃ゲ But probably didn't help I kept on smashing try limiter on the track and a few skid pans.
