hi all,
just reporting that my R34 GTT (grey/silver, manual) was stolen from Bundoora last night.
Rego: WCD-214
the car is manual, it has the following extras;
* 18" Volk Racing wheels with Hankook RS3s at the front and Federal RS-Rs on the rear
* Blitz front mount (return flow) intercooler
* 3" nismo exhaust
* JVC DOuble DIN cd player
It also has GZM Automotive stickers on both front and rear windows.
If spotted, PLease contact me on 047735477 or Constable Clemens at Mill Park Police on (03) 9407 3333
many thanks,
Goran
Ah, another Skyline without a proper alarm or immobiliser. When will people learn?
Neither will do shit against any crook with an ounce of knowledge.
The only protection against a thief is adequate insurance.
I knew a guy once in Ballina whos Harley got stolen.....from his garage....which had an alarm and surveillance....and metal f**king bollards in the doorway and the bike was literally chained to the concrete floor with big arse square chain. It was a Fatboy, too, so would have needed at least 4 people to carry. The bike also had an alarm and immobiliser.
  • Like 2
My bike got nicked from a gated complex; was steering locked and had a disc lock with an ear piercingly loud alarm that would go off just by moving the lock slightly - often set it off just undoing it. Found a screwdriver at the scene and that was it.
If they really want it, they will get it. All those things do is deter or stall for time. Insurance is the must.
  • Like 1
lol how is saying someone should put an alarm in their car harsh. Saying shit like "I had an alarm bit it got stolen anyway" just discourages people from installing one, resulting in more thefts.
And if it's installed correctly, the only way they will get it is by towing.
Well the thing is that's not what you said.
You had an 'I told you so' type comment.
Anyway, how do you know he didn't have an alarm?
  • Like 1
No, it encourages people to invest in insurance as an aside to an alarm and immobiliser. Just a bit unfair to assume OP didn't have any of this; for all you know he had both, left his car parked at home and wasn't home when it was stolen/towed.
Also, there are ways around alarms and immobilisers, besides a tow truck. You can tow a car with a strap easily. And as many kids as there are stealing cars, the guys with two trucks have not left town.
  • Like 2
    • Doing a refresh of my 33 and can see a few websites stating they sell the entire main carpet for our cars, but they all have generic photos which is fine, i understand they are custom made to order.  Just seeing if anyone has got it done or had any experience with this, as i would only want to do it if the fit and finish was as good as oem https://carmatsdirect.com.au/products/moulded-carpet-or-vinyl-for-nissan-skyline-r33-1993-1998-coupe https://knoxautocarpets.com.au/moulded-carpets/nissan/skyline/skyline-r-33-1993-1998/
    • Any plans for E85? If so, add flex fuel sensor.   I'd probably add in the sensors I mentioned above if the Link will support using them for engine protection. With water pressure, you need to be able to effectively set it that "If temp > X, and pressure = atmospheric, shutdown" as at running temp, you should be able to read pressure in the cooling system. If pressure suddenly disappears, it means the water went some where, and this is a quicker reaction than waiting on water temp to go up (Which, can take a little longer than you'd like, considering it now has to wait for hot air to heat it up) Oil pressure, Oil temp, both would be on my list too if you're looking to add sensors. Wideband O2. And at least one EGT sensor. If you're feeling deluxe, put in individual runner EGTs. Single EGT sensor is more so forget about a specific number, get used to "What is normal EGTs", and then keep an eye on it, if it starts going away from "normal" it's a sign something is wrong (Also, things like the tune can still start going out of spec, but EGTs may not show it, for example one injector starts running leaning, so ECU richens everything up, now 5 out of 6 cylinders are rich, and running cool, with one cylinder lean and running hotter, so it's not perfect) Then there is your other things to look at non sensor related, but you may have already done, or have underway, and that would be things like building a sump for more oil, and better oil control under high G-Forces (Cornering, brakes, acceleration). Basically, the above is worth looking/thinking about, if the ECU can do protective stuff with it, and you continue to use it how you are (Drive it to the track, thrash it, drive home, repeat once every 3 to 4 months)
    • Can also confirm these work a treat for most balljoints and bushes. If you have access to a big rattle gun, they make the job so much easier and quicker, compared to using a socket wrench or shifter on the c-clamp 👍
    • Its sort of street but got used for circuit sprints on account of I never drive it on the road because I dont have the time to spare. So it usage was sits around for months at a time then gets driven either 50 or 250 kms to the track followed by 20 laps followed by 50 or 250kms home followed by stuck in the shed until next time. So yeah neither fish nor fowl. Just dont want to break it on the track as a preference. Hence the fairly short sensor/mod list. Probably more worried about it pinging itself to destruction more so than anything oil related.
    • My thing I'd be doing, is pulling it out, and just getting the tune cleaned up for now. Before that even happens, checking over everything, like vac hoses, fuel hoses, etc. No point dropping thousands on sensors if the moment you start it back up all the oil leaks out, or it has massive vacuum leaks etc.   But really, to know what to do, depends on what your use case is. Hard core track car? Throw most sensors available at it. Street car, I'd probably just run oil pressure, oil temps, water pressure, water temp, probably fuel pressure too. I don't know exactly what the Link can handle and do with those though. And if it's mainly just to cruise the streets, rather than mountain runs, you can probably skip most of the above if you've already got them in as gauges and warning lights.   PS, inb4 "sell it and buy a modern sportscar"
